Hondata Q
Old Oct 18, 2003 | 03:59 PM
m3bluegsr's Avatar
Default Hondata Q
since i have a 97 gsr i have to get the obd2 to obd1 conversion harness but then do i need a obd1 gsr ecu?
Old Oct 18, 2003 | 04:29 PM
HXMan's Avatar
Default Re: Hondata Q (m3bluegsr)
Yes.
Old Oct 18, 2003 | 05:40 PM
TurboTegB18c's Avatar
Default Re: Hondata Q (HXMan)
If your running another intake manifold without the butterflies, u can run a p28 ecu which is usually cheaper then the gsr ecu.
Old Oct 18, 2003 | 07:05 PM
PHiZ's Avatar
Default Re: Hondata Q (TurboTegB18c)
I have ECUs and harnesses, PM me, and I'll also answer questions.
-PHiZ
Old Oct 18, 2003 | 08:35 PM
bluebullet's Avatar
Default Re: Hondata Q (PHiZ)
Hondata also has obd 2 p28 ECUs, then you don't need the conversion harness. Thats what I have.
Old Oct 19, 2003 | 08:00 AM
Hondata's Avatar
Default Re: Hondata Q (bluebullet)
And Hondata's software enables a P28 to drive the secondary intake runners on a GSR.
Old Oct 19, 2003 | 10:38 AM
PHiZ's Avatar
Default Re: Hondata Q (Hondata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondata &raquo;</TD></TR><TR><TD CLASS="quote">And Hondata's software enables a P28 to drive the secondary intake runners on a GSR.</TD></TR></TABLE>
How is that accomplished? Is it from using the A/C clutch line, or by using an automatic ECU, and using the A/T lockup solenoid?
-PHiZ
Old Oct 19, 2003 | 12:16 PM
m3bluegsr's Avatar
how much is the hondata p28 ecu then and thanks for answering my question.
Old Oct 19, 2003 | 11:11 PM
Hondata's Avatar
By either using the AC output or the purge solenoid output triggered by revs, speed and load.
Price 425 for the ECU with adapter + the S200 system.
Old Oct 20, 2003 | 03:47 AM
NOSED_CRX_VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondata &raquo;</TD></TR><TR><TD CLASS="quote">By either using the AC output or the purge solenoid output triggered by revs, speed and load. </TD></TR></TABLE>
Can you tell me how many aux's can be turned on and off via revs and load on a P28 ecu using hondata's software.
e.g. Nitrous solenoids / boost control solenoid valve / secondary intake runners ect ect?
PaJeeZy
Northern California (Sales)
Apr 5, 2009 02:57 PM
Milab21
Engine Management and Tuning
Jan 14, 2009 06:18 PM
Asahi
Aug 2, 2005 12:10 PM
Nextelbuddy
Jul 24, 2003 10:43 AM
StreetRacnGsR
May 11, 2003 02:18 PM
