Guys running t4's...
Old Oct 16, 2003 | 06:12 PM
PrecisionH23a's Avatar
Default Guys running t4's...
In first gear, what boost pressure do you usually hit? Give a brief overview your set-up as well as a/r sizing and amount of boost you run.
Old Oct 16, 2003 | 08:13 PM
Ricey McRicerton's Avatar
Default Re: Guys running t4's... (GudeH23a)
Correct me if I'm wrong, and I'm not running a T4, but would'nt you hit the same amount of boost in 1st gear as any other. (I'm a noob looking to learn..and I only run 7psi, so I hit 7psi long before I reach redline on my 15g)
Old Oct 16, 2003 | 09:11 PM
*Boostwerks*'s Avatar
Default Re: Guys running t4's... (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong, and I'm not running a T4, but would'nt you hit the same amount of boost in 1st gear as any other. (I'm a noob looking to learn..and I only run 7psi, so I hit 7psi long before I reach redline on my 15g)</TD></TR></TABLE>
Not exactly...at least in my case (SC50 on a ZC) the revs would climb so fast, that the turbo doesn't have enough time to fully spool.
I hit like 7psi in first, and then a full 10 in all the other gears...(This is a large part to why larger turbos are good for traction).
Old Oct 16, 2003 | 09:20 PM
Default Re: Guys running t4's... (Bryson)
Yep, I am not hitting full boost in first gear either. I reach redline VERY fast... On my other t3 set-up I used to have all I did is spin in first through third gear. I still spin, but it's not as bad.
Old Oct 16, 2003 | 09:47 PM
R6Elmo's Avatar
I get maybe 3-4 pounds in 1st. It simple goes by way too fast, especially with a SI/ITR tranny or the like.
Old Oct 16, 2003 | 11:01 PM
DLB1994's Avatar
Default Re: (R6Elmo)
am running a t3 turbine with the 60-1 and i can only get 15psi in 1st when am set at 20psi but my revlimter is only set at 7200 right now
DriveSlowHomie
Sep 27, 2005 05:54 AM
fafsa
Dec 5, 2004 07:46 PM
Burke
Apr 21, 2004 08:05 PM
ludelvr
Jun 24, 2002 12:31 AM
