are toda spec b cam too big for turbo charge?
Thinking of turbo charge my type r motor, but i'm currently running the toda spec b cam. Will it work? what is the biggest cam i can run with turbo?
Re: are toda spec b cam too big for turbo charge? (fd3st04r)
that is way to aggressive of a cam for a turbo set-up. You need a cam designed specifically for turbo and not all-motor.
Do a search on cams for your ITR... you will most likely find that the stock gsr ones are some of the best.
Re: are toda spec b cam too big for turbo charge? (GudeH23a)
stock gsr's are great. some of the fastest hot rod cars in the country still use stock cams. the typer cams are realy good but you loose some torque
Re: are toda spec b cam too big for turbo charge? (GOLDBERG)
Gary Gardella runs itr cams. John Bown had an itr exhaust and a gsr intake (I believe, or was it the other way around), he listed his setup on Ebay when he sold his race car.
Re: (shadyCTR)
yes signal auto runs spec b's in both of their choptop drag cars, and I've talked to at least two people, one with 300whp, and another with 508, that both ran the spec B's.
Re: (fd3st04r)
Mark @turbohonda.com is one, you can email him @ Turbohonda0@hotmail.com http://members.tripod.com/turbohonda0/
