darton or golden eagle
Old Oct 15, 2003 | 09:38 AM
redboost10's Avatar
Default darton or golden eagle
wanna sleeve my b16a2 so it can handle more boost. gotta 99 civic si. which sleeves should i go with? i wanna have them bored to about 83mm. are these sleeves closed deck, right?
Old Oct 15, 2003 | 09:44 AM
ekb18c's Avatar
Default Re: darton or golden eagle (jw11ae)
Hi, welcome to HT.
If you try doing a search for sleeves you will have more than enough reading material. I'm pretty sure it will keep you busy for days because this has been covered numerous times.
Try searching for Darton then Golden Eagle and all other variations such as GE, GEM etc..
Also try the archive posts also.
Modified by ekb18c at 10:55 AM 10/15/2003
Old Oct 15, 2003 | 10:38 AM
99integralsturbo's Avatar
Default Re: darton or golden eagle (ekb18c)
WOW in the amount of time it took you to say that you could have just given an answer.
Old Oct 15, 2003 | 11:36 AM
LiLOtaku's Avatar
Default Re: darton or golden eagle (99integralsturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99integralsturbo &raquo;</TD></TR><TR><TD CLASS="quote">WOW in the amount of time it took you to say that you could have just given an answer. </TD></TR></TABLE>
WOW in the amount of time it took you to say that you could have just given an answer. .
Both companies seem to be reputable, but I personally would go with Darton's and let RS machine do the work.
Mr. K20addict
147
Mar 24, 2008 10:04 AM
itr_18
Sep 19, 2005 07:28 AM
Da K00l Aid Mayun
Nov 11, 2004 01:32 AM
prestoned
27
Dec 8, 2003 07:32 AM
96cxt
Oct 21, 2002 11:54 AM
