B16 motor build.....few questions....
So I was planning on sleeving a GSR motor or going with a darton block, but something has come up to where I might be getting a free b16 block. No pistons/rings, just the block/crank. My question would be if I bore it to say 83.5 what size would it become, 1.8 or a 2.0 liter??? Also, have heard horror stories about b16's and all not making good power. I know when I did the previous turbo setup with JE 9.1:1 pistons, eagle rods, and arp head studs I made 274hp/218 torque @ 13psi....should I just go ahead and run 10.1:1 pistons instead of 9.1:1 or 9.5:1? I am shooting for 350-400hp @ wheels @ 18-20psi and going to be using the SC61 turbo with inline pro manifold. Any advice would be great!
Re: B16 motor build.....few questions.... (Bulldogg83)
big bore b16 makes plenty of pwer, and there are plenty of people on this board making large number's. I don't know the liter conversion.
With a good setup, 83mil bore, 10.1 (I would run 9.5ish
:1 myself, due to how much driving I do) w/ the SC61 is going to make 350-400hp around 15psi I would think.
also, be warned about starting out with just a block and crank!!! I just got done buying all the OEM parts to put mine together, and it added up to almost $1000(which is at a pretty discounted price)!!!!
It will be a nice feeling though, knowing that every nut, bolt, belt, hose, gasket, seal, etc....will be BRAND NEW!!!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 »</TD></TR><TR><TD CLASS="quote">So I was planning on sleeving a GSR motor or going with a darton block, but something has come up to where I might be getting a free b16 block. No pistons/rings, just the block/crank. My question would be if I bore it to say 83.5 what size would it become, 1.8 or a 2.0 liter??? Also, have heard horror stories about b16's and all not making good power. I know when I did the previous turbo setup with JE 9.1:1 pistons, eagle rods, and arp head studs I made 274hp/218 torque @ 13psi....should I just go ahead and run 10.1:1 pistons instead of 9.1:1 or 9.5:1? I am shooting for 350-400hp @ wheels @ 18-20psi and going to be using the SC61 turbo with inline pro manifold. Any advice would be great!</TD></TR></TABLE>
You will have no problems at all makign that power with an sc61, @18-20psi you should be well over 400...Im running a stock block b16a with thicker headgasket (~9:1 compression) and my first run on the dyno @14psi i made 315whp with a t3/t04e 60 trim .63 ar. (we had to turn it down, my injectors were maxed out)
NotPhilTran
01-12-2005 10:42 AM
