Strange behaviour at part throttle
Old Oct 16, 2003 | 08:13 AM
strangerqc's Avatar
Default Strange behaviour at part throttle
I'm running 6psi on a d16y8, 450cc and SMC+. I've tuned it on the dyno (full throttle) and got decent a/f ratio. BUT, when i'm at low or mid throttle and accelerating the car start to hesiate a bit, kind of a jerking motion. Does anyone have the same problem with a similair setup?
thank you
Old Oct 16, 2003 | 08:22 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Strange behaviour at part throttle (strangerqc)
Those are the injectors my friend
Old Oct 16, 2003 | 08:45 AM
raene's Avatar
Default Re: Strange behaviour at part throttle (HybridcivicLS-T)
Mine does that too, stock injectors, stock ECU... I think it's tuning My guess is the TPS being retarded.
Old Oct 16, 2003 | 08:51 AM
green_GSR's Avatar
You need to tune your partial throttle. When you tune your car at full throttle, it doesn't mean that your partial throttle is automatically tuned.
Old Oct 16, 2003 | 09:08 AM
strangerqc's Avatar
HybridcivicLS-T:
You mean that the injectors are the problem ? how come they are ok at full throttle ?
Old Oct 16, 2003 | 09:18 AM
strangerqc's Avatar
Default Re: Strange behaviour at part throttle (green_GSR)
Green_GSR:
I know that, but the SMC+ does'nt allow more than one fuel map, so i can't tune the part throttle
Old Oct 17, 2003 | 08:44 AM
strangerqc's Avatar
ttt
Old Oct 17, 2003 | 09:00 AM
Johnyquest's Avatar
you can't really tune open loop with the hack. just avoid it. the ecu tries to run stoich for open loop mode-- i don't think it's all that safe.
Old Oct 17, 2003 | 09:43 AM
Chrome Pipes's Avatar
Default Re: Strange behaviour at part throttle (Johnyquest)
When my o2 sensor went bad, at part throttle in open loop the engine hesitated like crazy. Just one more thing to check out after you tried everything else..
Old Oct 17, 2003 | 11:47 AM
CzanSOHC's Avatar
Default Re: Strange behaviour at part throttle (Chrome Pipes)
The fuel maps on the smc are very large. You are prolly just running really rich. The SMC is the problem, not your injectors.
Old Oct 17, 2003 | 12:50 PM
strangerqc's Avatar
Default Re: Strange behaviour at part throttle (CzanSOHC)
CzanSOHC:
Here's my fuel curve
You still think the problem is the SMC in open loop ?
Old Oct 17, 2003 | 12:57 PM
R6Elmo's Avatar
again, that is your fuel curve at WOT, and not at partial throtte/boost. There is a chance you are running too rich at partial throttle.
Old Oct 17, 2003 | 01:14 PM
inspyral's Avatar
Your car is jerking/hesitating under part-throttle because the SMC cuts your MAP signal to allow you to run those larger injectors(like the AFC hack). This problem is also common with the AFC hack.
platinum00
Dec 12, 2006 01:13 PM
aZnjCC
11
May 23, 2006 01:39 PM
turbohf
Jan 20, 2004 11:07 AM
StinkyTofu
Apr 17, 2003 05:50 AM
shamoo
Jun 18, 2002 12:07 PM
