Sohc Turbo transmission? Recomendations........
I am in the process of boosting a 95 dx motor, it will have a basic greddy kit installed. The dx tranny feels decent but I also have a ex tranny I was thinkin about throwin on when I do a clutch upgrade. What do you single cam guys think about swapping to a ex tranny? Too quick or do it since I am only going to be running 5.5 on this setup.
Re: Sohc Turbo transmission? Recomendations........ (Jdm_Rice_Monster)
5.5 psi? Do it. Although my buddy had an EX tranny put on his 00' DX and it didn't feel like shorter gears, but he could of just gotten screwed. But if you have an EX tranny already might as well try it out.
Re: Sohc Turbo transmission? Recomendations........ (sporkcrx)
Yeah thats what I figured. How big a diff. is there in the dx and ex tranny. I have done searches and no one really talks about the difference in them......just lots of talk about how sorry the cx and vx are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm_Rice_Monster »</TD></TR><TR><TD CLASS="quote">Yeah thats what I figured. How big a diff. is there in the dx and ex tranny. I have done searches and no one really talks about the difference in them......just lots of talk about how sorry the cx and vx are.</TD></TR></TABLE>
i would also like to know. im runnin a cx tranny on my jdm d15b vtec and let me tell u its slower than **** haha.. turbo goin in this weekend..
There's a pretty big difference in ex/dx trannys. I had my stock EX tranny then my friend broke it and i went to a 5th gen SI tranny which is essentially the same as an EX tranny. Another friend broke that one so i'm now on a HX tranny which is the same gearing as the DX and it's WAYYYYYY longer. EX goes like 1st to 30, 2nd to 60, 3rd to 90, 4th to 120. The HX is like 1st to 40, 2nd to 72, 3rd to 110, 4th to who knows.
Basically it takes a whole shift out of your 1/4 mile the gearing is so much taller but i'm getting like 30 mpg with the longer geared tranny. I can't really decide which i like more.
wow there are some pretty big differences in the tranny's
i had a DX tranny for a long time, just swapped an ex in about a month ago its way shorter feeling that the DX
that has been said before is even though the EX tranny is the close ratio of the SOHC, some say its still way longer in gears than an LS tranny
so for as boost goes, im goin with the EX tranny, but some say go with the DX....
heres some info from Mista Bones tranny page
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
DX/LX
1st-----3.250
2nd-----1.762
3rd-----1.172
4th-----0.909
5th-----0.702
Final Drive---4.058
CX /VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
from the DX to EX tranny
1st is the same
2nd is shorter in the EX
3rd is a tad shorter in the EX
4th and 5th same
but the main thing is Final Drive
a 4.058 DX to a 4.250EX is a pretty big difference...
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
Final Drive---4.250
DX/LX
1st-----3.250
2nd-----1.762
3rd-----1.172
4th-----0.909
5th-----0.702
Final Drive---4.058
CX /VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
1st is the same
4th and 5th same
Re: Sohc Turbo transmission? Recomendations........ (pornstarSR)
So it should be REALLY noticable with an EX tranny? My friend and I have always wondered if he actually has an EX tranny...wondering if there's a way to find out.
there is a code painted on the top of the tranny that will tell you but its easily washed off with solvent
alos i think there is a code on the case somewhere serial number or something near the filler plug something like p20XXXXXXX or s20XXXXXXX
and YES it should be noticable....
Re: (Pfieffdog)
An easy way to tell...1st gear winds out at almost 30mph in a dx tranny and closer to 20 in a EX tranny. EX trannys are much shorter than a dx tranny.
Re: (Marauder)
Damn I think he got fucked then. We'll throw the stockies on the front and see when 1st tops out.
so if it's a EX tranny it will have K4F in the serial number?
Re: (Ricey McRicerton)
Nah that's not true, when i still had my original tranny in my 00 ex 1st would go to about 32 instead of 42 in the current DX
Beause of the final drive difference the gears are a lot taller, i'm thinkin the dx tranny will make a good highway race setup with boost but off the line it might suck. When i get my SC50 on this week i'm gonna take it back to the 1/8 to see if i can pull another mid 8.
in a race situation dx and ex feel the same in first and second. not enuff difference for you to feel. but third is where it made the most difference for me. dx third was sooo long, it would be where i lost if i was meant to lose. ex third is shorter and pulls harder. ex over dx any day (except for fuel economy maybe) and 96-00 over 92-95 if u have a choice
Re: (sporkcrx)
Here's some more info from MistaBones page:
These tables will tell you how much your rpm's will drop when shifting. These numbers are for a steady speed shift. If you are accelerating they will be slightly higher due to clutch slippage and continued acceleration. Hybrid trannys also included. MPH numbers are for stock size tires, 22.7" overall diameter. MPH numbers for 5th gear are assuming enough power to overcome wind drag.
How to use these tables...If you shift at 6800 rpm using the DX tranny as an example, your rpm will fall to 3685 in 2nd, 4526 in 3rd, on so on.
DX
1st----3.250---0000/6800---34.8mph
2nd---1.761---3685/6800---64.3mph
3rd----1.172---4526/6800---96.9mph
4th----0.909---5274/6800---124.5mph
5th----0.702---5251/6800---161.3mph
Si/EX
1st----3.250---0000/7200---35.2mph
2nd---1.900---4209/7200---60.2mph
3rd----1.250---4739/7200---91.6mph
4th----0.909---5236/7200---125.9mph
Choose your 5th
5th----0.702---5560/7200---163.0mph
5th----0.750---5941/7200---152.6mph
5th----0.771---6107/7200---148.4mph
Hybrid using ZC 3rd and 4th gears
3rd----1.346---5101/7200---85.0mph
4th----1.033---5526/7200---110.7mph
5th----0.750---5228/7200---152.5mph
For 92-95 trannys it is best to use the HF/STD 3rd gear of 1.033 for 4th gear.
If you use the ZC 4th gear it will require grinding to fit the synchro hub.
DX
Si/EX
Choose your 5th
Re: (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR »</TD></TR><TR><TD CLASS="quote">im glad you reposted exactly what i did about 2 replys from the top...
WAY TO READ THE POST</TD></TR></TABLE>
Hehe
Hehe
Re: (pornstarSR)
Open your eyes friend. You didn't post the estimated speeds for the shift points. I was just trying to clarify and address the other responses. So sit down.
DeathByBoost
08-13-2006 07:53 PM
flatblakd15vt
14
03-22-2006 04:09 AM
PearlWhiteAccord
31
06-20-2004 03:40 PM
