turbo question please help
Old Oct 17, 2003 | 07:33 PM
fiftee_su's Avatar
Default turbo question please help
stock ls with drag 3 kit....everything stock...damn thing seems to be getting way too hot...its smokin...the turbo turned bright red around the area wehere it is connected to the manifold....thing was extremely hot....anyone kno why..havent had it tuned or anything.....turbo so frustrating..............
Old Oct 17, 2003 | 09:07 PM
Xtream's Avatar
Default Re: turbo question please help (fiftee_su)
That probily means you're running lean. Lean = Hotter, Ritch = Cooler, I suggest you tune your car ASAP.
Old Oct 17, 2003 | 09:52 PM
hondahvn's Avatar
is your cam timing on... opening the valve closer to the hottest part of the exhaust flame would definatly cause this
Old Oct 19, 2003 | 03:55 PM
fiftee_su's Avatar
Default Re: (hondahvn)
cam timing?????......im pretty sure the car is not running lean...a/f gauge reads fine for awhile but when it heats up then it juss dont owrk no more....weird...how much timing should be adjusted??
turbomaniac
Oct 11, 2017 05:19 AM
Jockobo
Oct 2, 2006 09:37 AM
sushibug
Jul 10, 2002 09:08 PM
