JB Weld Sucks !
Old Oct 15, 2003 | 10:48 AM
brkrnu's Avatar
Default JB Weld Sucks !
I did my turbo install over the weekend and had a bad experience with Ghetto welding.
JB'd my oil pan - broke when I tried to screw on my oil line
JB'd some brackets that hold my intercooler to my bumper support - broke right away !
There are too many other things to dick around with to have to put up with this crap. I went to get both of these things welded and would have saved myself time if I would have known how bad this stuff works on anything less than a perfectly prepared surface.... And yes, I did mix it right.
Moral of the story...... DO NOT USE JB Weld ON ANYTHING
Just my .02
Old Oct 15, 2003 | 10:50 AM
Blaze45's Avatar
Brrraaaap!
Default Re: JB Weld Sucks ! (brkrnu)
JB weld blows! Didnt hold on my sisters civic when I used it on the IM, I broke a chunk off...
Blaze
ScrapinSi's Avatar
no offense, but I have used JB Weld on many things over the years, and its only broken a few times on me...
Broke on an exhaust manifold (was being used as a temp fix... lasted almost 2 months)
Other than that, only little stuff I can think of...
Did you use JB Weld or JB Qwik? How long did you let it setup for?
Old Oct 15, 2003 | 10:51 AM
brkrnu's Avatar
Default Re: JB Weld Sucks ! (ScrapinSi)
The Quick ****. Maybe that was the reason.
Old Oct 15, 2003 | 10:53 AM
ScrapinSi's Avatar
only use JB Qwik in an emergency... I always try to use regular JB Weld
Old Oct 15, 2003 | 11:04 AM
ScottEK's Avatar
JB Weld, and like it says let it cure overnight before putting the object to use.
Old Oct 15, 2003 | 11:14 AM
MikeMAN's Avatar
if I recall correctly JB Quick is an epoxy for plastics only. so on u for that...if that isn't the case then, sorry to hear it didn't work out to well.
get her all welded up and let us know how boost is
mike
Old Oct 15, 2003 | 11:20 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: JB Weld Sucks ! (MikeMAN)
C'mon man......it's j.b. weld. It welds but it's not a welder............GHETTO. Half *** jobs get half *** results.
Old Oct 15, 2003 | 11:22 AM
CzanSOHC's Avatar
Jb weld is perfect for certain things, but anyone for uses it for their oil pan deserves the weld to break and their motor to die of oil starvation.
Old Oct 15, 2003 | 11:24 AM
VTC_CiViC's Avatar
Default Re: JB Weld Sucks ! (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">C'mon man......it's j.b. weld. It welds but it's not a welder............GHETTO. Half *** jobs get half *** results.</TD></TR></TABLE>
Exactly. Don't blame JB Weld for your decision to go ghetto instead of doing it the right way.
Old Oct 15, 2003 | 11:30 AM
gritsak's Avatar
Default Re: JB Weld Sucks ! (VTC_CiViC)
the regular jb weld works great in the right applications...i personally have a welding place close to me that does awsome work so i wouldnt use it on something major (bov, i/c, oil pan, ect.) but for little things that are out of site and dont have a ton of pressure/strain on them it works good
EDIT: i see your in dayton...take your pan to d&m welding on arbor blv....its right up next to johnny mac. they charge a flat fee of $20 per hour so for 15min of welding it still is $20 but they do really good work, ive gone to them almost a dozen times and never had a complaint
Old Oct 15, 2003 | 11:36 AM
M.A.R.C.'s Avatar
Default Re: JB Weld Sucks ! (CzanSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CzanSOHC &raquo;</TD></TR><TR><TD CLASS="quote">Jb weld is perfect for certain things, but anyone for uses it for their oil pan deserves the weld to break and their motor to die of oil starvation.</TD></TR></TABLE>
such kind words lol. yah... i mean it's jb weld... if it doesn't work as best you thought it would... what do you expect?
Old Oct 15, 2003 | 02:14 PM
Bailhatch's Avatar
Default Re: JB Weld Sucks ! (CivicRyda2k)
i can't belive people are still doing this. motors cost sooooo much more than a couple little welds!!! weak
Old Oct 15, 2003 | 02:15 PM
Shaun's Avatar
my freind and I used jb weld on my oilpan, worked well, giving it time to dry is the key
Old Oct 15, 2003 | 02:25 PM
ScrapinSi's Avatar
Default Re: (Shaun)
I used neither on my oilpan... I used a 45 degree brass fitting with StratOseal washers on both sides... And I loctited the nut on there... It aint goin nowhere
Old Oct 15, 2003 | 02:27 PM
LbcJiGGa's Avatar
Default Re: (Shaun)
true dat. Let it dry for one day gets better results.
Old Oct 15, 2003 | 02:39 PM
Howitt's Avatar
Default Re: (LbcJiGGa)
If you need it tig welded let us know, Ill bring out the aluminium stick and throw you a bead on it.
Old Oct 16, 2003 | 02:19 AM
89dxhunchback's Avatar
Default Re: (Howitt)
Just have to do 2 things.
#1 Let the damn fitting sit for a day.
#2 use something to hold the fitting in from behind. Put the JB weld everywhere the fitting touchs the oil pan and fittng, then screw the other part on the fitting from the back ( inside the pan ), then just for "good mearsure" cover the rest of the area around the fitting ( inside and out ) with JB weld.
My retard dad tried to use it one time to fit a 1/8 gap between the #1 and #2 cylinder deck on my old 5.0, not a good idea... I guess he meant well...
Old Oct 16, 2003 | 03:29 AM
swlabhot's Avatar
Default Re: (89dxhunchback)
Looks like u found out the hard way. If u'd asked about it here 1st, u would have stayed away from it. Booost + JB =
Old Oct 16, 2003 | 05:02 AM
ScrapinSi's Avatar
Default Re: (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote"> Booost + JB = </TD></TR></TABLE>
Not necessarily true... My friend has a dodge shadow, and he JB Welded his BOV flange onto his charge pipe, and it held for 2+ years at 20+ Psi...
Its all in the application and the drying...
Old Oct 16, 2003 | 05:08 AM
DA-MAX's Avatar
Default Re: (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">my freind and I used jb weld on my oilpan, worked well, giving it time to dry is the key </TD></TR></TABLE>
same here...JBd the pan on my old Maxima...6 months and it stayed strong. but when it got cold for some reason it started cracking a little. but its good stuff if used right. I've heard of guys JB welding cracked engine blocks before....dunno if its true but damn
Old Oct 16, 2003 | 05:37 AM
PM-Performance's Avatar
Default Re: (DA-MAX)
jb weld works great if you use it right and on the right things. would i ever use it on oil pans and to hold intercoolers to my car? NO
Old Oct 16, 2003 | 05:41 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">would i ever use it on oil pans and to hold intercoolers to my car? NO </TD></TR></TABLE>
Exactly, what the hell were you thinking?
Old Oct 16, 2003 | 06:18 AM
luti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">
I've heard of guys JB welding cracked engine blocks before....dunno if its true but damn </TD></TR></TABLE>
I've read of a guy (or team) who took 2 I4 engines from a motorcycle (think it was a Honda bike too) and JB Welded them together to make a V8 bike. Only the blocks were JB Welded together, the crank and other stuff like that was custom, but still, pretty impressive. But yes, on a daily driver, JB Weld has its place, and the oil pan is not the rigth place.
Old Oct 16, 2003 | 06:34 AM
Default Re: (luti)
Venom JB welds cracks in their blocks and race thme like that , i saw thew hole dipstick tube thing cracked all apart and they jb welded it all up and ran it next event
