Unsafe to drive with no BOV?
Old Oct 18, 2003 | 04:59 AM
ITSTOCK's Avatar
Default Unsafe to drive with no BOV?
Im having issues with bov flanges, and my turbo should be all done this weekend but i wiont be able to get my flange problem worked out till sometime next week, so my question is, is it safe to drive around with np bov for a week or so?
Old Oct 18, 2003 | 05:03 AM
civictypenos's Avatar
Default Re: Unsafe to drive with no BOV? (ITSTOCK)
yes,many cars with stock turbos dont even have BOV's.
Old Oct 18, 2003 | 08:28 AM
Ricey McRicerton's Avatar
Default Re: Unsafe to drive with no BOV? (civictypenos)
Yup..especially if your car is an automatic...in an automatic car the throttle body plate doesnt snap shut between shifts, so there is less backpressure on the turbine. A week isnt going to hurt your turbo either way though.
Old Oct 18, 2003 | 08:39 AM
fastludeh22's Avatar
Default Re: Unsafe to drive with no BOV? (Ricey McRicerton)
when you let off the gas, try to do it gradually, dont just slam it shut. compressor surge is not a good thing
Old Oct 18, 2003 | 08:45 AM
lazerus's Avatar
Default Re: Unsafe to drive with no BOV? (fastludeh22)
you should be fine.
Old Oct 18, 2003 | 11:16 AM
Johnyquest's Avatar
Default Re: Unsafe to drive with no BOV? (lazerus)
nobody mentioned this... but it'll be fine as long as the BOOST IS LOW! keep it at like 5lbs or so for the week, and if you do go higher, do NOT slam the throttle shut. a really bad high boost surge can work the nut right off the impeller and it'll fall apart (worst case scenario) or just break things. At low boost, it's fine (greddy kit has no BOV @ 5.5psi) but at high boost it's a must.
Old Oct 19, 2003 | 05:59 AM
ITSTOCK's Avatar
Default Re: Unsafe to drive with no BOV? (Johnyquest)
thanks guys, but i got my bov setup
Jayboy
May 12, 2005 10:57 PM
desert eagle
Jan 20, 2005 07:10 PM
XxRoCkMaNxNEOxX
Nov 5, 2004 07:30 PM
99AccordTurbo
Aug 12, 2004 07:36 PM
pip9
Apr 18, 2004 07:34 AM
