D16a6 with D16y8 head...head studs?
Old Jun 24, 2004 | 09:48 AM
unsungsohc's Avatar
Default D16a6 with D16y8 head...head studs?
like the title says i have a d16a6 matched up with a d16y8 vtec head. which arp head studs do i use? thanks for the help
the only ones offered on their site are:
Civic D16Y 208-4305
Honda D16Z - Only 208-4301
Old Jun 24, 2004 | 09:31 PM
unsungsohc's Avatar
Default Re: D16a6 with D16y8 head...head studs? (unsungsohc)
bump for the night
Old Jun 25, 2004 | 10:12 AM
unsungsohc's Avatar
no ideas?
Old Jun 25, 2004 | 11:23 AM
Boltz's Avatar
not sure about A6 + Y8 but....
I have a Z6 head + Y8 block and ARP z6 studs..... They all fit but one, which was replaced by a stocker.
That doesnt answer your question, but may help put you in the right direction
Old Jun 25, 2004 | 10:38 PM
unsungsohc's Avatar
Default Re: D16a6 with D16y8 head...head studs? (Boltz)
thanks. i am just trying to figure out what part numbers to use because the combo falls right in the middle. anyone else have any idea?
Old Jun 25, 2004 | 11:14 PM
Evil EG's Avatar
I just assembeled my a6 y8 mini me and i used y8 studs... They all fit but one and it was to long so I cut it to the right length. The z6 studs are shorter and wont even come out of the top of the head. Also the reason the one bolt is to long is because the hole in the block isnt deep enough but the a6 head makes up for that by making the bolt sit up higher in one spot, so you need to cut the last bolt shorter for the y8 head since it dosnt compensate for the smaller hole in the block like the a6 head.
B_Swapped93
Mar 22, 2014 07:25 AM
B18B1-Crx
Dec 2, 2011 09:59 PM
Cruiser G
Sep 19, 2009 09:43 PM
red civic standard
Mar 26, 2007 07:56 AM
