** Greddy Gauges Help **
I'm looking into purchasing some greddy gauges locally, and he took pictures of what it comes with, but i'm not 100% sure if comes with everything i need to install / use them.
Here are some pictures of what I would be getting...
EGT
Oil Pressure
PLease let me know if anything is missing...
Thanks In Advance!
EGT
Oil Pressure
Thanks In Advance!
Re: ** Greddy Gauges Help ** (integlspwr2k)
Looks like the EGT has everything except the bung and nut (no biggy anyhow) and I'm not sure on the Oil Pressure, but I think there is another plug the goes from that black plug with wires to a plug at the guage. I'm not positive though
your good! All you need is the egt bung(below) in order to mount your egt probe:
And Greddy Oil block adapter to mount your oil pressure sensor and oil filter:
Of course there are other places to mount your oil pressure sensor..but this makes it a lot simpler and better. Because with this greddy oil filter adapter...you can also source an oil feed line from here, and also mount an oil temperature sensor here incase you decide to invest in one. And on top of that..you'd be feeding filtered oil to your turbo
A greddy egt bung can be bought for like 25-30 bucks and the Greddy block adapter can be had for 50 to 60 bucks.
Khoi
Modified by Sohc Driver at 12:57 AM 6/24/2004
Khoi
Re: ** Greddy Gauges Help ** (JDMH22HATCH)
oh yeah..he is missing something for the oil pressure guage. I just took a picture of my stuff...your missing the plug that will connect your sensor to the actual Greddy Guage like JDMH22HATCH stated above
Khoi
Khoi
Philly_NBP_R
05-11-2006 07:31 AM
BlueShadow
02-03-2005 08:27 AM
