used JRSC with uberdata
Old Jun 21, 2004 | 10:38 AM
Brad's Avatar
Default used JRSC with uberdata
I recently purchased a used JRSC. All the parts I got are pictured below, can anyone tell me any parts I'm missing that I'd have to order from a JRSC dealer? It didn't come with an fmu, but since I'll be using uberdata I won't need it.
Also this sensor looks a little messed up. Does it look useable? From the instructions it looks like I'm missing the pressure relay that it connects to. Do I need all that with uberdata?
Thanks
Old Jun 21, 2004 | 10:56 AM
prestonpark's Avatar
Default Re: used JRSC with uberdata (Brad)
dont need it wihtt he relay
Old Jun 22, 2004 | 08:33 AM
Brad's Avatar
Does the stock fuel rail work, and is there a part I need that rotates the fpr?
Old Jun 22, 2004 | 08:35 AM
RacerXI's Avatar
The stock FPR will work, but there is an adapter to rotate it. You are missing a few misc. bolts, washers, and etc., but my brain is mush right now.
Old Jun 24, 2004 | 10:53 AM
roadrunner's Avatar
The brass fitting next to the smashed white pressure switch on the manifold is for the brake booster. You'll need to replace that...
Old Jun 24, 2004 | 02:37 PM
MADEINIRAQ's Avatar
Default Re: (roadrunner)
you can use a first gen b16 fuel pressure regulator and not need the thing that rotates it.
Ldo
Feb 23, 2010 09:24 PM
out_of_order
Jun 19, 2004 12:24 PM
hondamanwill
Mar 12, 2004 02:06 PM
