Mini-me meet HT, HT, meet Mini-me.
1 Post
nice to meet ya!
Ron(Sixtydashone) will be using this exact manifold on his upcoming 10 second buildup.
Wastegate goes where the yellow circle is on the collector.
Performance should be similar if not BETTER than some of my other manifolds, mainly because of less runner length, which means less heat-loss.
AC versions are soon to follow, for B and D series engines right now(H possibly to come).
1 Post
Re: Mini-me meet HT, HT, meet Mini-me. (revhardracing)
I hope to replace the SST with this. If it performs like I think it will, only the blingers will want the SST. Everyone else should want this, especially w/AC.
1 Post
Re: (vietjdmboi)
Its pretty much out, turbo location is done(same as AC SST), just have to weld it together. I created this thread to gather interest so that people know what the manifold is when its spoken of around the forums.
Re: Mini-me meet HT, HT, meet Mini-me. (Tinker219)
Looks good Cody. I guess my ac sst (which I'm still waiting patiently for ) is going to be the last of it's kind.
1 Post
Re: (macrosshn)
Oh yes, for the AC, you will have to go half radiator, and move the AC condenser for the turbo to swing out. This was designed to fit a t4/60-1 with AC and a 3" DP w/Vband.
Re: (Tinker219)
Cody with the ac version, if your using say a t3 turbo will you still need to move the ac condensor or would it be possible to keep it where it currently is.
Re: (Tinker219)
Looks good Cody.
Guys, please dont discuss pricing in threads like these. We are happy to have vendors introduce products, designs and ideas to the forum, but we also appreciate those companies that assist us with running the site by sponsoring. Its not courteous to them to have threads like this with open price discussion.
What are some of the benefits of this, aside from the heat issue. What effect does runner length have?
<---Nick, who is trying to steer this thread towards tech discussion and not peanut gallerying
1 Post
Re: (evil newgsrdriver)
Tech stuff...hrmm. Ill give it my best shot!
The runners are co-joined in function with the collector.
The SST for example:
there is a VERY pronounced and long collector, and then very pronounced, and long runners. The long collector is great for smoothing out exhaust pulses, etc. But, there is a downside; the length of all the runners bleeds off a lot of heat. Although the thicker material helps, you will still lose heat through the runners.
With this manifold:
there is a combination of both. Thick tubing, short runners, and a "mini" merge collector. They all should work together to provide similar, if not BETTER power characteristics than most tubular manifolds on the market.
Now some may bring up the equal length problem. There is a 3.5" difference in lengths between the 1&4 and 2&3 runners. The SSTs are 2.5" difference, so 1 inch difference in runner lengths between this manifold and the SST(or similar designs). That one inch would be HARD pressed(or the 3.5" for that matter) to measure in terms of spoolup/power.
Not to mention better fitment on the car, lower under-hood temps, etc etc.
With this manifold:
Re: (ELSpool)
This sort of applies to any of your manifolds, but what is your favorite way to deal with the areas where the weld interferes with the nuts that hold it to the head? It looks like several of the upper ones would not sit against the flange but maybe it's just the pic. I was thinking some type of bit that has a tip you could put into the mounting hole and then machine out a flat spot just the size of a manifold nut... a grinder just seems so cruel on such nice parts.
