No oxygen sensor, hurt performance?
Old Jun 23, 2004 | 05:36 AM
Coleman's Avatar
Default No oxygen sensor, hurt performance?
Just boosted my car and somehow the 02 sensor got lost on the install. I have a 1 wire O2 in the downpipe to block off the hole, but it is not connected. How much performance am I hurting by not running an 02? It is a P61 92 GSR ECU
Lestat
Old Jun 23, 2004 | 05:48 AM
B16A1-EF9's Avatar
Default Re: No oxygen sensor, hurt performance? (Lestat)
I'm sure without it the computer can't adjust properly. If your running rich enough that it won't make much of a difference then your ok as far as blowing the motor. I would get the o2 in there as soon as you can though.
Old Jun 23, 2004 | 07:26 AM
B18C1CYA's Avatar
Default Re: No oxygen sensor, hurt performance? (B16A1-EF9)
yes no o2 will effect the performance of it i had a bad o2 but never made a code and had some strange problems, then replaced the o2 and all better
Old Jun 23, 2004 | 07:50 AM
Too_Smooth's Avatar
WOT it won't hurt you because the oxygen sensor doesn't make any adjustments. Other than that you'll most likely burn more gas durning part throttle conditions.
Old Jun 23, 2004 | 11:19 AM
Vtec92Civic's Avatar
Default Re: (Too_Smooth)
yeah . . . . . I ran without an o2 sensor when I first installed my turbo setup and everything was all good. I wouldn't do it forever but it is ok to drive it like that for a little while.
Old Jun 23, 2004 | 03:09 PM
turboH22Aakkord's Avatar
i'm pritty sure without the 02 it won't go out of warm up value, it wont' go into closed loop... (i get closed and open loop confused but i'm pritty sure closed is right)so it wont' run tip top, it will run like your car runs when it first starts.. but it will run fine... i believe.
Old Jun 23, 2004 | 03:23 PM
Misfit's Avatar
Default Re: No oxygen sensor, hurt performance? (turboH22Aakkord)
what about a bad primary O2 with Hondata S200B?
4tika4
Jul 25, 2009 05:23 AM
odishaw
Feb 16, 2008 08:34 AM
ken2830
Feb 1, 2008 12:09 AM
boost fed ls
Aug 31, 2004 07:45 PM
Red_Si
Jul 2, 2002 01:28 AM
