boost leak?? HELP
Old Jun 21, 2004 | 07:25 AM
skierGT's Avatar
Default boost leak?? HELP
when i turned up my boost to 8lbs today on the actuator of my internal wastegate i noticed it doesnt stay at 8 lbs. As it spools up it hits 8lbs at about 3500 untill 4500 then it drops to 5 psi and stays there till redline.
do i have a leak in my piping?
does my IC suck that bad?
is it something vac line related?
or is my int. wastegate broke?
Help please
Old Jun 21, 2004 | 08:20 AM
B16Drag's Avatar
whats the turbo size?
Old Jun 21, 2004 | 08:23 AM
Mag00n's Avatar
Default Re: (B16Drag)
If it was leaking it wouldnt be holding a constant psi to redline. My bet is something with the internal wastegate.
Old Jun 21, 2004 | 09:14 AM
skierGT's Avatar
Default Re: (SICKSOLVTEC-T)
its the 15g turbo d16z6 kit
should i run the vac line to the manifild instead of the turbo housing because of my intercooler?
Old Jun 21, 2004 | 09:32 AM
Mag00n's Avatar
Default Re: (skierGT)
Yes. I think it is pretty much agreed on by all that the wastegate vacuum is better off coming straight from the manifold.
4_door_teg
Jun 26, 2006 09:15 PM
chriskey0829
Feb 1, 2006 07:10 PM
W.Zero
Jan 16, 2005 02:49 PM
blackfrohatch
Aug 26, 2003 06:47 AM
