Mopar T3 turbo inlet side? What is needed?
For a Mopar T3 turbo I notice that they do not have the protruding cone, what is needed to make this work correctly on a honda? Sorry, I am new to FI
Re: Mopar T3 turbo inlet side? What is needed? (IDriveHonda)
If you're referring to the turbo off a Chrysler 2.2 turbo, then you'll need to either fabricate a flange yourself or get one cut. Then again you could locate the OEM cast aluminum piece and cut the flange off...
Re: Mopar T3 turbo inlet side? What is needed? (turbopimp)
It's from a daytona, and where you put an air filter normally there is no snout that sticks out, it is pretty much flush.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveHonda »</TD></TR><TR><TD CLASS="quote">It's from a daytona, and where you put an air filter normally there is no snout that sticks out, it is pretty much flush.</TD></TR></TABLE>
Just put a piece of paper over the opening and use a pencil to shade a pattern, then use that as a template to fabricate a flange out of a thin piece of aluminum or steel. You can do all of this with just a handsaw, a hand drill and a hole saw that matches the opening of the turbo inlet diameter. Once you have the flange made, have a tube welded onto the flange and attach the filter to the tube. It's really not that dificult, it'll should take less than hour to make.
you got a T3 off of an 84-87 unintercooled 2.2 . they have the TB before the turbo inlet, right on the compressor side. crap design. TU sells what i think your looking for, check it out. it's an adapter to put a hose on or whatever you want to use it as a "normal" turbo.
http://www.turbosunleashed.com/ordering.htm (scroll down)
a little pricey.
a little pricey.
Re: Mopar T3 turbo inlet side? What is needed? (GLHS895)
That is exactly what I was looking for, thank you. I also noticed that the exhaust housing flange is a bit different anyone have any experience with this compared to a normal T3?
Modified by IDriveHonda at 6:26 PM 6/23/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveHonda »</TD></TR><TR><TD CLASS="quote">I also noticed that the exhaust housing flange is a bit different anyone have any experience with this compared to a normal T3?</TD></TR></TABLE>
how is it different? no really, i don't have much experience with any turbo's other than mopar 2.2's. pics for comparison?
ok, i see. i forgot all about the differences between a T3 flange, and a Mopar T3 flange. you could probably drill another hole, but it doesn't look like you'll have enough room. it would be like a slot or something. but probably still work.
it's like that because where the turbo bolts up on a 2.2 space is CRAMPED. plus there is the block-to-turbo support bracket in there. they had to offset that bolt just so it could work.
another option would be to see about getting a new, bigger T3 exhaust housing with a standard flange. stock that thing is .48 A/R.
You can swap the exhaust housing with a "normal" one from a Ford 2.3 liter turbo, just make sure to get one with a .63 ar if you don't want to choke power at higher rpm. The Ford style housing is industry standard, meaning it'll bolt up to any manifold designed to fit a T3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopimp »</TD></TR><TR><TD CLASS="quote">You can swap the exhaust housing with a "normal" one from a Ford 2.3 liter turbo, just make sure to get one with a .63 ar if you don't want to choke power at higher rpm. The Ford style housing is industry standard, meaning it'll bolt up to any manifold designed to fit a T3.</TD></TR></TABLE>
good idea.
good idea.
