bad seal or oil return line??
Old Jun 21, 2004 | 08:29 AM
civictypenos's Avatar
Default bad seal or oil return line??
we have a t28 mounted to a hf manifold.guy wanted to keep his a/c so we had to make an adaptor to turn the turbo.this placed the turbo very low when compared to the oil pan.so the length on the line is short and it is mounted very low in the oil pan.
the car smokes,very badly.it coming from the turbo becuase there is no oil at all in any of the pipes any where or on the plugs any where.
question:is it the seal on the turbo from the oil return line?
question:if i fix the line,does the turbo need a rebuild?
question:since space is very limited,could i run the line to the back of the pan like on the greddy kits that use the oil plug?
its oil smoking into the exhaust piping but nothing through the comp side,does that sound like a seal leaking from the oil return side?
Old Jun 21, 2004 | 10:43 AM
Redwidow's Avatar
Default Re: bad seal or oil return line?? (civictypenos)
Sounds like a drain back issue what size feed and return lines do you have?
Old Jun 21, 2004 | 05:46 PM
Default Re: bad seal or oil return line?? (Redwidow)
proabaly an4 fed and about 5/16th drain i think.
Old Jun 21, 2004 | 07:41 PM
RA166E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">it is mounted very low in the oil pan.</TD></TR></TABLE>
This is what I had to change in my engine when I first got it. The return line was below the oil level of the pan. Put it above the oil level no more smoke. Problem solved.
Good Luck
Old Jun 22, 2004 | 04:13 AM
Default Re: bad seal or oil return line?? (RA166E)
how did you figure out where the oil level is at?i have almost no room to move it or else fitting will be to high to have a downward slopeto drain.its in a sohc ,just how far is too low?
Old Jun 22, 2004 | 07:12 AM
integlspwr2k's Avatar
i know whats the problem..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">we have a t28 mounted to a hf manifold.</TD></TR></TABLE>
Get something better then that ghetto rigged setup.
Old Jun 22, 2004 | 08:27 AM
Redwidow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">proabaly an4 fed and about 5/16th drain i think.</TD></TR></TABLE>
AN4 is going to cause to mouch pressure in the turbo, I'd switch to a AN3 I had to becasue too much volume of oil
Old Jun 23, 2004 | 07:57 AM
k,we will switch out the feed line,any ideals on the return line?ill take a pic and you guys tell me what ya think.
exactly where is a good point to tap the oil pan at?
Old Jun 23, 2004 | 08:04 AM
DaX's Avatar
DaX
Loved
Community Favorite
I tapped my pan in the deep part, as high as i could. Be sure to put your return between two holes for the oil pan studs, or you'll be sorry.
Old Jun 24, 2004 | 07:46 AM
any more input?thanx guys.
Old Jun 24, 2004 | 04:33 PM
omrigaron's Avatar
i had the exact same prob your having. mine was smoking so bad i would get pulled over, it was really bad. the prob was that the return line was both too small diameter and it wasnt above the oil line causing back pressure in the turbo and burning it off when it couldnt push it out fast enough. i got a bigger hose and put it highest up on the oil pan as possible and BAM, no more probs. and no turbo damage either, but i took care of it it like 6 or so days after it was originally installed.
Old Jun 24, 2004 | 05:03 PM
RA166E's Avatar
Just took a pic of mine. It used to be about 3" lower and smoke like crazy.
Old Jun 24, 2004 | 05:18 PM
thanx guys,im guessing that has to be it.now my probelm will be how to get it up any higher than it already is.the turbo sits pretty low.
Old Jun 30, 2004 | 08:22 AM
finally had time to jack the car up and check it out.the return line is at the bottom of the pan.there is oil around the turbo housing as well where it joins to the exhaust side.in this pic you can see right where the turbo joins,the oil is seeping around the joint.
Old Jun 30, 2004 | 05:54 PM
up
Old Jun 30, 2004 | 06:30 PM
turbopimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">how did you figure out where the oil level is at?i have almost no room to move it or else fitting will be to high to have a downward slopeto drain.its in a sohc ,just how far is too low?</TD></TR></TABLE>
Maybe this will help.
http://www.lightningmotorsport...n.gif
Old Jul 1, 2004 | 05:21 AM
Default Re: bad seal or oil return line?? (turbopimp)
very nice,thanx alot.
to those of you who did have this problem,did your turbo have the same looking leak as mine?between the exhaust housing and the center section.
Old Jul 18, 2005 | 10:24 AM
DriveSlowHomie's Avatar
bringing this thread back from the dead because my turbo looks exactly like that turbo...my drain is just like the one above though correctly, the only thing is that it kinda sits going sideways to clear the dp...what other possibilities is there besides bad oil return line?...bad seals?...no oil in my pipes though
Old Jul 18, 2005 | 01:54 PM
TunerToys's Avatar
Default Re: bad seal or oil return line?? (cmGSR916)
To determine the proper entry point for your oil return line, two things are critical.
1. It must be downhill all the way from the outlet of the turbo, all the way into the oil pan. All Downhill!
2. The entry point into the pan must be above the level of the oil in the pan. This is not only for the oil to be able to drain into the pan downhill, but for blow-by issues as well.
To determine the entry point on the pan. Remove the pan from the engine. Clean it out. Position the p[an where it approximates the tilt it is installed at on the engine. Fill it with the equivalent amount of liquid of your choice (like water, oil, etc.). Then pick a point on the pan, above the level of the liquid and centered between two pan bolts. Also be aware of any baffling in the inside of the pan.
(Shameless Plug Alert)
For -10 AN installs, where punching a huge hole in the pan is not desired, you can use on of these drain flange fittings, bolted through the pan wall.
http://tunertoys.zoovy.com/product/ODFAN38K
Craig
jprelude92
Aug 30, 2008 07:12 AM
"00"R
Jun 21, 2007 10:48 AM
btech
Jun 16, 2007 07:17 PM
slo_crx
Oct 6, 2004 08:30 AM
hackish
May 17, 2004 09:45 AM
