is it ok to run oil feed line under/next to oil pan
is it ok to run my oil feed line under the turbo, between the oil pan and tranny upwards to the T in the back of the block? will this pose any problems? and does it matter which way the L shaped adapter for the feed line on the turbo faces up or downward?
Re: (c2nap)
ok good, just needed another opinion of assurance 'cause not too sure about how hot the temperatures maybe down there and if it'll affect the ss braided line.
Re: (not so civic)
The only problem I forsee with that is that you might have to take the turbo off if you need to take off the line. Mine was leaking at first so I actually used a 3 inch brass extension to bring it forward so that I could troubleshoot the leaks, and now Im too lazy to change it.
