who boosts AND sprays?
Old Jun 22, 2004 | 11:06 PM
Tex Blackwell's Avatar
Default who boosts AND sprays?
who has done it w/ what kit on a stock engine? what about with a zex dry kit?
i cant find any info on this set up
anyone know anything, PM me,
Modified by mp3albums2k2 at 1:22 PM 6/23/2004
Modified by mp3albums2k2 at 5:49 PM 6/23/2004
Old Jun 23, 2004 | 07:03 PM
AROD's Avatar
i do , use nos or any type of we direct port sysem. It is fully tunable with fuel and nos. THE BEST WAY TO GO. also use some kind of activation switch either rpm or pressure switch
Old Jun 24, 2004 | 09:35 PM
Default Re: (1.83Tc)
unfortuantely my firend already bought a dry kit, how much psi should the fuel pressure be turned up? a few pounds or what?
Old Jun 24, 2004 | 10:31 PM
Turbo-Honda's Avatar
To anser your question is depend on how lean while spraying. It not just turning up psi on fuel and expect to run 75 shot, stock internal and be safe on the motor..
For a 75 shot, you need to buy a good fuel management to run safely or say good bye to your motor if you just buy the kit and spray it w/o knowing what damage it will cause...
I hope that make more sence...
Old Jun 25, 2004 | 04:00 AM
AROD's Avatar
just turn up the fuel pressure 1 or 2 psi , the kit comes with a safty switch if it senses low FP then the system shuts off. A 75 shot is not that big you don't need to retard your timing from stock.
Old Jun 25, 2004 | 05:37 AM
m R g S r's Avatar
Yea, you can run a 75 shot, but not too much boost along with it.,
Old Jun 25, 2004 | 05:43 AM
ZEX Man's Avatar
Default Re: who boosts AND sprays? (mp3albums2k2)
Do NOT run a dry kit on a boosted application, unless you are using a stand-alone with a separate nitrous enrichment fuel map. A single nozzle wet system will work just fine for you. Nitrous and boost were made for each other...I run 250hp of nitrous on a 375whp SOHC. It lives and makes great power, just make sure you pull out at least 2 deg. of ignition timing for every 50hp of nitrous you use.
ZEX Man
Old Jun 25, 2004 | 06:02 AM
m R g S r's Avatar
Default Re: who boosts AND sprays? (ZEX Man)
Zexman, That's not a stock block is it?
Old Jun 25, 2004 | 06:44 AM
ZEX Man's Avatar
Default Re: who boosts AND sprays? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Zexman, That's not a stock block is it? </TD></TR></TABLE>
Nope....Darton sleeves.....
ZEX Man
Old Jun 25, 2004 | 12:19 PM
why cant a dry kit be used? it would only be used this weekend, vafc hack is the only sort of management being used. wouldnt the box increase the pressure enough for the nitrous? it only has 2 last a 1/4 mile.
Modified by mp3albums2k2 at 5:13 AM 6/26/2004
Old Jun 25, 2004 | 12:21 PM
Default Re: (m R g S r)
it would be only 8 pounds on the stock sir2 b16
Old Jun 25, 2004 | 12:33 PM
ZEX Man's Avatar
Default Re: (mp3albums2k2)
When you engage a dry kit, fuel pressure increases to 60-80psi. On top of that, your injectors need additional fuel pressure to properly meter fuel under boosted conditions. This means an additional 10-40 psi, depending on what style of regulator of FMU you are using. This means you need a fuel pump that will supply the volume you need at very high fuel pressures.....70-110 plus psi. Most standard high volume pumps do not supply much fuel at these elevated pressures. As far as your justification that you only need to use this for the weekend, 1/4 mile at a time, it only takes a couple seconds to destroy your engine if your fuel pump can't keep up. Either way, if you don't trust what I am saying, go ahead and spray away, maybe you will be lucky and everything will run great............good luck...........
ZEX Man
Old Jun 25, 2004 | 04:41 PM
Hispeed's Avatar
Default Re: (ZEX Man)
[qoute]When you engage a dry kit, fuel pressure increases to 60-80psi. On top of that, your injectors need additional fuel pressure to properly meter fuel under boosted conditions. This means an additional 10-40 psi, depending on what style of regulator of FMU you are using. This means you need a fuel pump that will supply the volume you need at very high fuel pressures.....70-110 plus psi. Most standard high volume pumps do not supply much fuel at these elevated pressures. As far as your justification that you only need to use this for the weekend, 1/4 mile at a time, it only takes a couple seconds to destroy your engine if your fuel pump can't keep up. Either way, if you don't trust what I am saying, go ahead and spray away, maybe you will be lucky and everything will run great............good luck...........
ZEX Man[/quote]
^^^^^^^^^^ word from the wise. heed the warning!!! ^^^^^^^^^^^^
Old Jun 25, 2004 | 07:59 PM
will a walbro 255 fuel pump keep up w/ the dsm injectors at 8 psi?
Old Jun 25, 2004 | 08:16 PM
rooflz's Avatar
a stock fuel pump will keep up with the injectors at 8psi, stock fuel pump is good for cars pushing 14lbs of booost, wat hes talking about is the supply for nitrous and boost which a stock fuel pump Ive seen before is capable of putting out.. For how long? I dont know, I know we run a sohc non vtec @ 8lbs of boost with a 50 shot of nitrous with no issues thus far, and hes probably sprayed over 15 times since boosted and before the boost he was spraying a 75 shot.. Now keep in mind his block hasnt been touched, he has 88k on the odometer and to no avail its running like a champ, sometimes i wanna believe its luck of the draw because another kid thought it would be an awesome idea to spray after getting beat by the sohc that im talking too, well 2 weeks goes by and he pulls up ready to race again, he installed a zex kit, boom their off and running sure enough when both cars hit the funny gas what happens? The kids motor **** the bed and our sohc just kept on moving..
if it was me, ona stock block id probably get a fuel pump, run about 8lbs of boost and shoot 50-75 depending on who i was racing or wat times i wanted to hit.. Enjoy
Old Jun 25, 2004 | 08:29 PM
Default Re: (rooflz)
also, 2 step colder plugs would be used, i'll be at the shop now,
so bump the fuel pressure up a couple pounds?
and keep the same retardation i have for the boost, which seems pretty well off.
so if anyone could please give me a call on there 2 cents worth, i would really apreciate it.
tex @ 980-521-2224
Old Jun 25, 2004 | 08:43 PM
rooflz's Avatar
want to be completely safe then yes retard timin about 2-4 degrees of timing, you'll lose some power but the 75 shot will more then make up for it.. as for turning up the psi on the fuel i might give it a a couple of lbs more just for the fact that its better to be rich then it is to be lean ya know..
all of this is bootleg, you should get a hondata or some form of engine management to be alot safer, but ive also seen my uncle tune cars running 10 second 1/4 miles with no more then a set of wrenchs.. Hes part of the older crew that want nothing to do with buttons and software n what not..
Old Jun 26, 2004 | 07:47 AM
isnt there some kind of calculation that sets the amount of retard that should be set depending on how much boost and spray is going to be used?
93civiczex
Dec 28, 2008 07:04 AM
Gant
Jan 7, 2005 06:17 PM
YourHondaSucks
Feb 9, 2004 11:38 AM
revsportz
Aug 31, 2001 08:56 AM
