car wont boost anymore
Old Jun 21, 2004 | 05:57 PM
Egone's Avatar
Default car wont boost anymore
ive been turbocharged for about 3 months now and yesterday the turbo stopped boosting it all started when i took it for a rip in 5th but i noticed something was off when it was only boosting 0.09 bars i then tested it in 1st and it boosted to 0.25bars then the boost just died off and hasnt been boosting since its a 14b turbo with the internal wastegate ?? any ideas? ive checked for leaks and doesnt appear to be any so im aiming at the wastegate ive got it set at 4psi right now
Old Jun 21, 2004 | 08:45 PM
Turbo E's Avatar
see if the WG opens and closes smoothly
Old Jun 21, 2004 | 08:50 PM
Egone's Avatar
hey turbo e i opened it with the flathead pushing the lever down and it opens smoothly im pretty sure thats where the problem is as i just bumped the boost up 1 psi yestrday
Old Jun 21, 2004 | 09:44 PM
Drew Peacock's Avatar
Default Re: (Egone)
Is the turbo making any noise? Put the tip of a long handled screwdriver on the compressor cover, when the cars running listen to it through the handle you may have to get someone to rev it up a bit aswell.
Old Jun 21, 2004 | 11:33 PM
Egone's Avatar
nope no noise, im going to check the wategate the internal flapper may be stuck open
Old Jun 22, 2004 | 12:15 AM
SBCCIVIC's Avatar
Default Re: (Egone)
check the charge pipes they may have came loose
Old Jun 22, 2004 | 05:24 PM
Egone's Avatar
double checked the pipes all tight im leaning more towards the wastegate
Old Jun 22, 2004 | 05:30 PM
MiraiZ's Avatar
Default Re: (Egone)
check the turbine to see if the blades still spin freely
Old Jun 22, 2004 | 06:59 PM
Egone's Avatar
checked that also turbo spins freely doubt the turbo's blown i guess i'll see when i pop off the housing to check the wastegate flapper anyone know how to fix it if the flappers stuck?
Old Jun 22, 2004 | 07:13 PM
MiraiZ's Avatar
Default Re: (Egone)
a tap with a hammer or a mallet?
Old Jun 23, 2004 | 12:34 AM
Egone's Avatar
ive tried hitting the housing and nothing im going to take it all apart and see if the flappers stuck open, maybe its time for a external wastegate
Old Jun 27, 2004 | 01:41 PM
Egone's Avatar
Default Re: car wont boost anymore (Egone)
checked it out today and it seems that my wastegate is open at idle and while i rev the car which is why its not boosting anyone have a clue whats wrong?? could it be the wastegate actutator?
tallblondkid
Nov 24, 2013 03:55 PM
MiMiK
Dec 10, 2005 06:21 PM
RFd15bhatch
May 24, 2005 12:27 PM
*Boostwerks*
Aug 18, 2004 11:28 PM
COLORPROS
May 21, 2003 07:53 AM
