Defi gauges (pictures)
This is why i need a single pod, i dont care who makes it anymore, i just need a 52mm pod.
Wiredspeed should be sending me one, but its already been 3 weeks.
Re: Defi gauges (Jordo)
[QUOTE=Jordo]
QUOTE]
Tell me about it. I've been waiting for about the same amount of time for my gauge pod.
QUOTE]
Hey Jordo, how do you like those guages?? And how hard was it to install them?? I have the EGT, Boost and oil pressure, but they are still under my bed .
12 Years Strong
Re: Defi gauges (carbonDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonDelSol »</TD></TR><TR><TD CLASS="quote">Pretty nice lookin...how'd you find a gauge cluster to match...or are all those defi gauges to in the dash?</TD></TR></TABLE>
Thats a stock ITR gauge cluster yo!
Re: (TheShodan)
get one of these
Vendor: Auto Meter Products, Inc.
Product Line: Auto Meter Gauge Mounting Cups
Material: Steel
Finish: Black
Diameter: 2 1/16 in.
Mount your gauges anywhere.
2 1/16 in. diameter, black, mounting cup
Auto Meter gauge cup allows you to mount your gauges on the dash, below the dash, or outside on your hood cowl for that Pro-Street look. With great looks and function, this mounting cup is sure to be a hit.
part number
ATM-2204
12.95$ from summitracing.com
Material: Steel
Finish: Black
part number
ATM-2204
Re: (project dc2)
I looked at those but I figured they hold the gauge to high off of the steering coloum and will block out too much of the speedo/tach. So I machined my own out of aluminum....
Here are some pics....
Re: (Blackack26)
You'd be better off putting your EGT in there. Let the engine management worry about overboostin/boost-cut.
If you have a problem, EGT will tell you long before a boost guage.
But, on topic - LOOKS AWESOME!
I have a triple pod in my Teg (A/F, EGT, BOOST)with the dual cluster pod (OIL PRESS, VOLTS) as well. I put a shift light right where you have your boost guage.
A littel too much to handle.....
Re: (Turboteggy)
yeah thats the exact setup im doing, my greddy ring should be getting here soon.. then i can mount it on my steering hub
