ACL bearings question
Old Jun 21, 2004 | 05:10 PM
Cyber ITR's Avatar
Default ACL bearings question
i ordered acl bearing kit for my b18c1
but on the box it says:
application to suit b18a1
are they the same ??
thanks
Old Jun 21, 2004 | 05:11 PM
ninesecrx's Avatar
Default Re: ACL bearings question (Day Walker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker &raquo;</TD></TR><TR><TD CLASS="quote">i ordered acl bearing kit for my b18c1
thanks</TD></TR></TABLE>
Nope, the ls motor bearings are wider.
Old Jun 21, 2004 | 05:23 PM
Cyber ITR's Avatar
Default Re: ACL bearings question (ninesecrx)
what about the thrust washers, Mike ?
thanks
Old Jun 21, 2004 | 05:26 PM
Rod.'s Avatar
where did you get it from??
Old Jun 21, 2004 | 05:28 PM
Cyber ITR's Avatar
Default Re: ACL bearings question (redturbocivic)
some guy that used to be a sponsor in this forum
i wont name him just yet, ill give him some time to sort this **** out
even if he wants me to return them to him, it would still cost money
since i live in new zealand ..... pissing me off
Old Jun 21, 2004 | 05:29 PM
The Destroyer's Avatar
Calm down man, im sure you will get your situation worked out.
Old Jun 21, 2004 | 05:37 PM
Cyber ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, the ls motor bearings are wider.</TD></TR></TABLE>
Mike, he gave me the ACL part number here
Main bearings B16,B17,B18 # 5M1959 $71.72 $45.08
Main bearings B21,F ,H series #5M1937 $90.27 $56.74
Main bearings D16 ALL #5M1957 $80.89 $50.84
Rod bearings B16A, #4B9641 $57.75 $36.39
Rod bearings B18A1 #4B1946 $63.46 $39.89
Rod bearings B18C1, 5 #4B1925 $63.46 $39.89
Rod Bearings B21,F,h series #4B1936 $48.76 $30.79
Rod Bearings D16 ALL #4B1956 $60.10 $37.77
Thrust washers ALL HONDA/ACURA call for # $7.99 $4.99
Bearing kit set B16A #B16KS $135.00 $99.00
Bearing kit set B18A,B #B18ABKS $135.00 $99.00
Bearing kit set B18C1,5 #B18CKS $135.00 $99.00
Bearing kit set F,H series #F&HKS $145.00 $99.00
Bearing kit set D series #D16KS $145.00 $99.00
so looks like that b18c main bearings = b18a1 ?
the rods bearings i received says it is for b18c1, so thats ok
Old Jun 21, 2004 | 06:22 PM
ninesecrx's Avatar
Thats true, I just thought you got all LS bearings. You could still even run the LS rod bearings if u cut the insides to clear the crank journals...sounds like ur good to go
Old Jun 21, 2004 | 10:05 PM
earl's Avatar
The bearings you should have are
5M1959
4B1946
1T1957
all B16/18 mains and thrusts are the same. It is just the rod bearings that are different. If he gave you b18c rod bearings, they should work ok in your ls rods
Oh, how is Camp doing?
Old Jun 22, 2004 | 04:26 AM
Cyber ITR's Avatar
Default Re: ACL bearings question (earl)
thanks for the replies
earl : i didnt buy it from camp
chippy
10
Sep 9, 2007 06:35 AM
pumpkyn
Oct 6, 2006 02:26 PM
BeeEK9R
27
Jun 27, 2006 05:02 AM
amazinspiderman
11
May 16, 2006 06:31 PM
marcussmith26
Jan 28, 2006 01:45 PM
