spot the difference??
Old Jun 23, 2004 | 07:13 AM
djnikko's Avatar
Default spot the difference??
can anyone tell me what the difference is between a normal o2 sensor and a wideband o2 sensor? looking at the two I cant seem to tell the difference. Is it just the simple fact that one measures against a wider band?
thanks
Old Jun 23, 2004 | 07:18 AM
warrick's Avatar
Default Re: spot the difference?? (djnikko)
five wires versus four or one.
Old Jun 23, 2004 | 10:10 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">can anyone tell me what the difference is between a normal o2 sensor and a wideband o2 sensor? looking at the two I cant seem to tell the difference. Is it just the simple fact that one measures against a wider band?
thanks</TD></TR></TABLE>
Here we go.......
A narrowband o2 is a 0-1 volt sensor that will read a "narrow" o2 content area.. Its about 14.4-15.1 or around there..
A wideband o2 is a 0-5 volt sensor that will read a "wide" o2 content area.. Not sure of the ranges of these but they will cover the entire band that you need for tuning.. Keep in mind that just the sensor is useless without the process unit that comes with the wideband..
Old Jun 23, 2004 | 10:36 AM
djnikko's Avatar
Default Re: spot the difference?? (tgreaves)
ah i see thanks guys. how much are the sensors roughly? and is every wideband sensor the same? i.e. 0&gt;5volt
Also is there any "ghetto" solutions for making the process unit?
Thanks for your help guys
Old Jun 23, 2004 | 10:49 AM
tgreaves's Avatar
Just go to http://www.wbo2.com and get a techedge unit.. Do it the correct way since your going to be tuning your car with this.. The techedge units are cheap and work great.. Dont forget to convert the prices on their website from AUD to USD..
Old Jun 23, 2004 | 01:24 PM
tegmech's Avatar
dont forget this one http://www.innovatemotorsports.com/
