Is my motor Blown ?
Old Jun 22, 2004 | 01:39 PM
1boostedcivic's Avatar
Default Is my motor Blown ?
My car feels like its running on 3 cylinders. so i check my plugs and found that in cylinder 4 my spark plug is melted.( ill try to upload some pics a lil. later.)
no compression at all in the 4th cylinder. the compression test showed 185, 195, 180, 10. So when i take out the spark plug wire in cylinder 4, the car runs the same. Im thinking i cracked a piston or something this was boosting 7 psi on a semi-heavily modified d16z16(cam, valvesprings, skunk2 im, and msd igintion) maybe burnt valves? has anyone ever seen this before? cause if its that, then i'll just drop in some new valves and a headgasket and im good to
Old Jun 22, 2004 | 01:46 PM
legendboy's Avatar
Default Re: Is my motor Blown ? (1zexxedcivic)
That would be an affirative
Old Jun 22, 2004 | 01:47 PM
bump i wanna know what you guys think
Default Re: Is my motor Blown ? (legendboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote">That would be an affirative</TD></TR></TABLE>
huh?
Old Jun 22, 2004 | 01:49 PM
DA9-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1zexxedcivic &raquo;</TD></TR><TR><TD CLASS="quote">
huh?</TD></TR></TABLE>
Translation: Yes
Old Jun 22, 2004 | 02:02 PM
Default Re: Is my motor Blown ? (DA9-T)
that would be a yes to a cracked piston or some new valves.
Old Jun 22, 2004 | 02:24 PM
Frozen E's Avatar
H-T White Ops
That would be a "yes" to either way you have to tear your motor appart and do a rebuild.
Old Jun 22, 2004 | 04:25 PM
MiraiZ's Avatar
Default Re: (IslandSi)
Use a pen light and peek in the spark plug hole...if you see any oil in there, then things may not be so good.
Old Jun 22, 2004 | 04:28 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Just take of your head and see for yourself. Either way that is what you are going to end up doing anyway.
Old Jun 23, 2004 | 08:52 AM
Default Re: Is my motor Blown ? (rochesterricer)
oh it doesn't matter, with fjt pistons being soo cheap, i minus well rip open the block and become another d-series ninja. thanks for the help guys
Old Jun 24, 2004 | 10:59 AM
does anyone know where i can find some pg6 rods for cheap new or used?
AnthraxVX
Sep 30, 2006 07:09 AM
spliffsta2
Jun 14, 2006 06:35 AM
encognito
Sep 19, 2004 06:28 AM
Orangecivic251
10
Jun 17, 2004 07:11 PM
project142
Jan 28, 2004 06:06 PM
