If you had the choice...
Old Jun 23, 2004 | 08:15 AM
RTW DC2R's Avatar
Default If you had the choice...
...between a SLEEVED 84mm bored 1.8L block, or SLEEVED stock bore 84mm 2L block, which would you choose for a high boost (20-25psi) turbo setup (with forged internals, low compression) and why? Can you give me some pro's and con's? This is assuming both blocks can be had for about the same price, and Im not worried about being able to "rev out" the B20. I blew up my all motor ITR block and want to go turbo but not sure what block to go with. Thanks
Old Jun 23, 2004 | 10:25 AM
Turbocivic94's Avatar
Default Re: If you had the choice... (RTW DC2)
It doesnt make a bit of difference. they both would do the samething. Only difference is crank.
Old Jun 23, 2004 | 10:34 AM
RTW DC2R's Avatar
The B20 has a stock 1 piece sleeve though, the B16/18 doesnt. Does that make a difference when it comes to sleeving the motor for boost?
As far as the cranks go, would one be any better than the other for boosting? Could I swap my ITR crank into the B20 block assuming the ITR crank isnt damaged?
Thanks
Old Jun 23, 2004 | 06:07 PM
RTW DC2R's Avatar
does nobody know? or is this something thats asked 100 times a day?
Old Jun 23, 2004 | 08:08 PM
Trak_Day's Avatar
New User
Personally i went with a bored b18c1 to 84 mm. I havent driven it yet, but i like the idea that there is a bit of room to fix a problem. And i am not real sure why, but I still am not a fan of the B20vtec.
Old Jul 2, 2004 | 08:16 AM
Default Re: (DroppedGSR)
just keep ur ITR block and bore it to 84mm
Old Jul 2, 2004 | 09:37 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (Turbocivic94)
it's got a big *** hole in it.
Old Jul 2, 2004 | 09:47 AM
bluebird's Avatar
Default Re: (boostincoupe)
I have seen alot of people here in so-cal that have great success with the built b20vtec motors.. Since you are sleeving it you are getting rid of its weak point..
Old Jul 6, 2004 | 01:34 PM
I would go with ls block and get it sleeved. It would be cheaper
be18see1
Mar 14, 2008 01:12 PM
lakai_19
Feb 13, 2008 04:08 PM
7rrivera7
11
Jul 29, 2006 09:51 PM
godzhand
Apr 25, 2006 12:43 PM
majek
Oct 14, 2004 02:49 PM
