Greddy CEL after WOT...please help
Old Jun 24, 2004 | 02:23 PM
94greddycivic's Avatar
Default Greddy CEL after WOT...please help
anyone get this ....after i hit full boost i get a check engine light that pops on...if i turn the car off it goes away till the next time i hit full boost for a couple seconds..
setup
d16z6
p28 ecu
E-manage
15g greddy turbo
1g intercooler
1g bov
the emanage doesnt throw a code only the car does....i know other people have this problem does anyone know what it is
Old Jun 24, 2004 | 02:26 PM
iiilgsrlll's Avatar
Default Re: Greddy CEL after WOT...please help (94greddycivic)
What's the code?
Old Jun 24, 2004 | 02:32 PM
SpoolnG2's Avatar
Default Re: Greddy CEL after WOT...please help (iiilgsrlll)
i bet your throwing a map code. If your not using a missing link the map sensor is reading boost. most likely thats your problem
Old Jun 24, 2004 | 02:33 PM
iiilgsrlll's Avatar
Default Re: Greddy CEL after WOT...please help (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">i bet your throwing a map code. If your not using a missing link the map sensor is reading boost. most likely thats your problem
I agree. Either that or Code 16 injector failure code. Those are the 2 common ones with the blue box or Emanage.
Old Jun 24, 2004 | 05:23 PM
can i use the missing link with the emanage since the emanage works off the map....also the emanage doesnt throw any codes just the car and its still pulls hard when the code is on..even thought i dont like to push it with it throwing the CEl
Old Jun 24, 2004 | 07:02 PM
bump for a check engine light
Old Jun 24, 2004 | 08:54 PM
FBP Si 2000's Avatar
No way to find out what code the car is throwing with the emanage hooked up?
Old Jun 25, 2004 | 04:34 AM
i was told by other people that the code is a "Too Rich" code....i guess its better then a too lean code....The car seams to run fine with it on and the E-manage still is displaying the green light...so i think it will be okay...
any other thoughts
Old Jun 25, 2004 | 05:19 AM
Old Jun 25, 2004 | 10:24 AM
bump
Old Jun 25, 2004 | 01:18 PM
MachAF's Avatar
no one is going to help you unless to give us the code.
your pissing me off by bumping this thread up.
next time you bump this thread up with no code I'm gonna slap you with my dick
The emanage will not show any ECU code dude. If your check engine light is on that is noooo good. Check the code. If you don't know how go to http://www.c-speedracing.com and look there.
Old Jun 25, 2004 | 07:34 PM
code 22.....and my vtec wont engage
Old Jun 25, 2004 | 08:24 PM
Default Re: (94greddycivic)
22 VTEC pressure valve
I think that's correct...got it off the civic section.
Old Jun 26, 2004 | 05:50 AM
Default Re: (FBP Si 2000)
how come that code will come on after about 4 seconds of boost....even though im not hitting my vtec point.......i figured it was the map reading boost , but it was this code
Old Jun 26, 2004 | 05:51 AM
also my vtec will not activate.....im thinking loose connection so i will have to go over all the connections today
Old Jun 26, 2004 | 10:43 AM
went over the connections and im still getting thhe vtec pressure switch code and no vtec...puzzles me that im getting the code when i dont even rev near vtec.....someone lend me some insight
eggie75
Apr 7, 2008 01:40 PM
2ltrsnailpwr
Oct 24, 2003 03:33 AM
platinum00
Jul 25, 2003 09:16 AM
platinum00
Jul 24, 2003 08:02 AM
Bspec18
Mar 26, 2003 11:04 PM
