question on wideband setup??
Old Jun 24, 2004 | 02:43 PM
ludetech
Guest
Posts: n/a
Default question on wideband setup??
I dont want a air fuel gauge that gives me an inaccurate reading and is useless. I want a guage that tells me my actuall air/fuel ratio in digits. I dont know much about them and I searched a bit. got some mixed information and now I just have even more questions about them.
can I hook a wideband to my stock ecu OBDII (00 prelude sh) I will be running vafc hack?
whats this I hear about you need a controller?, do I need a hondata/ems to run one of these?
is it possible to get one of these gauges that will cosmetically match up with my silver greddy 60mm gauges?
how much do they run? I got mixed answers (350$-1000$) depending on gauge.
Also do these things adjust fuel also or do they just read it out?
Thanks guys
Old Jun 24, 2004 | 02:54 PM
crawdad689's Avatar
Default Re: question on wideband setup?? (ludetech)
i'd run hondata at least before you worry about a wideband
how many lbs are you hoping to run w/ your vafc hack?
wideband O2's like FJO, etc.... are $ and i'd be worried about compatability issues w/ vafc
Old Jun 24, 2004 | 03:19 PM
ludetech
Guest
Posts: n/a
compatibility? how do they work together? does the wideband hook up to the afc? Im gonna run about 7 psi of boost. I was just gonna use a narrow band but I want something more accurate thats all
Old Jun 24, 2004 | 03:23 PM
crawdad689's Avatar
Default Re: (ludetech)
i wouldn't worry bout a wideband AT ALL if you're only running 7 lbs
Old Jun 24, 2004 | 03:32 PM
ludetech
Guest
Posts: n/a
I dont want to lean, I want a fugin wideband. I want to make sure I dont lean out. also with the setup Im running after my motor pops I will be building my motor to something much more capable. I dont want to get anything else but a wideband
now can someone answer these questions and stop telling me what I need to worry about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludetech &raquo;</TD></TR><TR><TD CLASS="quote">compatibility? how do they work together? does the wideband hook up to the afc? Im gonna run about 7 psi of boost. I was just gonna use a narrow band but I want something more accurate thats all</TD></TR></TABLE>
Old Jun 24, 2004 | 04:01 PM
eddyboy's Avatar
Well in terms of compatability, Your VFAC and Wideband don't talk to each other. Just think of your wideband as a external meter or sensor for your a/f.
You then must interpret what your wideband is telling you about your a/f and then make appropriate changes to your fuel management.
BTW if you getting a wideband you might as well look into Uberdata. Getting a wideband is the biggest expense when going uberdata, Since you already want one, it would probably only cost you another $50-100 to get yourself ready for uberdata.
GL
Old Jun 24, 2004 | 04:13 PM
boosted_dc2's Avatar
Default Re: (crawdad689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawdad689 &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't worry bout a wideband AT ALL if you're only running 7 lbs</TD></TR></TABLE>
this statment makes NO sense. dont listen to this.
if you want a wideband that goes with your guages then you should look at the aem ugeo guage version. its like 650 bucks. your other options can be found here. https://honda-tech.com/zerothread?id=635792
i have the techedge and got it for 200 bucks, the display is small and i like it.
Landon
Old Jun 24, 2004 | 04:24 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (eddyboy)
Uberdata is great if you can find base maps that match your setup or your able to spend ALOT of time on a dyno and make your own map and tune it. As for a wideband, http://www.zeitronix.com/Products/zt2/zt2.htm is the best one that I have found so far IMO. You can look around and see what you like. Going lean will blow your motor, but so will to much timming, so if you want your motor to last, retard the timming and run it rich, about 12.5-13.0 and your motor should last as long as you take care of it.
good luck
Blaze
MisterB
May 12, 2005 05:51 AM
Yambor
Apr 29, 2005 09:39 AM
Boner_Ben
Nov 10, 2004 11:16 AM
ludetech
Jun 24, 2004 07:48 PM
VTC_CiViC
Sep 17, 2001 11:31 AM
