PGMFI inling pump wire.. QUICK question!
Old Jun 22, 2004 | 01:45 PM
tyflip2's Avatar
Default PGMFI inling pump wire.. QUICK question!
i cant find the pgmfi relay on my 96 civic but i was told to hook up the inline pump i need to splice into the yellow wire with the green stripe on it. i can find that wire going through the firewall but cant find the plug. is the wire ALWAYS YELLOW WITH GREEN STRIPE?? i need to know before i cut that one. if anyone can help me please do. thanks alot
Old Jun 22, 2004 | 02:14 PM
tyflip2's Avatar
Default Re: PGMFI inling pump wire.. QUICK question! (tyflip2)
really need help!!
Old Jun 22, 2004 | 02:17 PM
onePOINTsix's Avatar
,i wouldn't hook it up directly the pgmfi or main relay as it's more commanly known. Just hook up a seprate relay to a ignition switched power source and that way you dont have to worry about blowing out a $50 main relay
edit: here's a pic for eveyone
Modified by Sideout at 6:40 PM 6/22/2004
Old Jun 22, 2004 | 09:29 PM
Flamenco-T's Avatar
Look under the driver side dash. It should be by the fuse box, you will see a brown socket over a white box. The wire will be the last one on the socket layout. You will see it, I can take pics tmw if you like.
stan
Old Jun 22, 2004 | 10:55 PM
tyflip2's Avatar
Default Re: PGMFI inling pump wire.. QUICK question! (Flamenco-T)
i found the plug, but it was behing my glove box on my 96 civic. thanks for the help though
FW_EJ8
Dec 17, 2007 06:03 PM
g2turbo
Jul 6, 2006 09:49 AM
hatchback_al
Oct 26, 2004 10:00 AM
rice4life
16
Sep 4, 2002 12:39 PM
echo999
Oct 15, 2001 05:00 PM
