ZEX dry nitrous...is 100 shot ok!
B18c1 in hatch been squeezin 75, is it safe to squeeze a lil bit more without ***BOOM**** blowing my motor up!
Re: ZEX dry nitrous...is 100 shot ok! (Frosty18)
ive got b18c1, with skunk2 im, headers out, walbro 255, mallory ignition, msd cap-wires, aem cam gears...stock head/block, full exedy clutch set-up, stock injectors. What do you guys think....hittin 12.8s all day with this set-up and wanna go a little lower.
Damn, 12.8's is very fast just for 75 shot. I would advice you to go with the wet if you want to go 100 shots. And also retard another 2 degree of timing.
Re: ZEX dry nitrous...is 100 shot ok! (tkHBseries)
I ran 100 shot with the Zex dry kit on my D16Y8. You will not be able to do it safely with stock injectors though.
im in the process of throwing a hondata s200 now....my car has just been tuned and everything should be running perfectly....as i believe. im still not fully convinced on squeezin 100 shot dry on my set-up though...i guess it'll be a gamble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkHBseries »</TD></TR><TR><TD CLASS="quote">im in the process of throwing a hondata s200 now....my car has just been tuned and everything should be running perfectly....as i believe. im still not fully convinced on squeezin 100 shot dry on my set-up though...i guess it'll be a gamble. </TD></TR></TABLE>
Injectors?
Injectors?
get some larger injectors and you should be good...
2 headgaskets would deffn be safer though
hbboostman
14
12-24-2007 08:32 AM
digital sol
05-10-2007 08:48 PM
