Second hand Turbos
Old Jun 24, 2004 | 02:49 AM
boostdc's Avatar
Default Second hand Turbos
Hey guys, i was just wondering if you would use a second hand turbo on your cars.... Reason being that there are alot of them out there and they are fairly cheap!!
Also i hear the play in the shaft is important, but what else should i look for when purchasing a second hand item......
Thanks in advance....
Old Jun 24, 2004 | 06:55 AM
B18bEK's Avatar
do it do it.
Old Jun 24, 2004 | 08:05 AM
MooreBoost's Avatar
Default Re: (B18bEK)
I bought a 14b off a guy with 100% positve feedback from 112 people on ebay, he said it was in great condition. I recieved the turbo, it had ZERO shaft play, I bolted it up only to find it had blown seals. Now I gotta rip it all apart and find another turbo. Be careful.
Old Jun 24, 2004 | 08:22 AM
B18bEK's Avatar
my turbo is 3rd hand, never been rebuilt and still in perfect condition
Old Jun 24, 2004 | 08:41 AM
fastcivicboy's Avatar
yeah when your buying a second hand turbo try to make sure it has minimal shaft play and no shaft play in and out. Also look to see if there's excessive oil on the fins or on the turbo. If the turbo's drinched in oil pass it up man it's going to need new seals. If your pulling it out of the car look at the mielage and cond. of the engine your pulling it out of. That can pretty much overall tell you what the turbo has been through. Hope I helped a little.
Old Jun 25, 2004 | 12:05 AM
boostdc's Avatar
Default Re: (fastcivicboy)
thanks guys for the heads up. i will be looking out for a nice T3 flanged turbo to purchase, possibly one from a skyline....
hmmm... so Absolutely no play back and forth? but ok side to side??
Old Jun 25, 2004 | 07:45 AM
carbonDelSol's Avatar
Default Re: (boostdc)
I bought a second hand turbo and was completely misled on the "flange size", now I get to make myself an adapter plate! Just make sure you know what you may be getting into
Old Jun 25, 2004 | 10:12 AM
Joseph Davis's Avatar
Default Re: Second hand Turbos (boostdc)
There is no such thing as a good used turbo; there are only good rebuildable cores. TRUST me, I am the one and only junkyard warrior.
Old Jun 25, 2004 | 10:27 AM
tgreaves's Avatar
Default Re: Second hand Turbos (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">There is no such thing as a good used turbo; there are only good rebuildable cores. TRUST me, I am the one and only junkyard warrior.</TD></TR></TABLE>
Uhhh.. You sure about that.. My turbo came from the junkyard and its mint.. And look at my title..
Old Jun 25, 2004 | 11:21 AM
Default Re: Second hand Turbos (tgreaves)
You're a junkie... I was dubbed junkyard warrior a couple years back.
I'm not saying you can't get a good used turbo... I'm just saying the odds are against you. $60 for a rebuild kit and an hour to install it is a good deal, IMO.
Modified by J. Davis at 11:50 PM 6/25/2004
Old Jun 25, 2004 | 11:25 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">You're a junkie... I was dubbed junkyard warrior a couple years back.
I'm not saying you can't get a good used turbo... I'm just saying the odds are against you. $60 for a rebuild kit and an hour to install it is a good deal, IMO.</TD></TR></TABLE>
There is alot of crap out there and it kinda sucks when you spend a little while to pull stuff of so you can even test the turbo just to find its locked up or has wobble to it..
If you wanna find a good turbo its best to know what turbos are on what cars.. And if you find a car that has the hood open and you can clearly see the turbo than its probably bad or someone else would have had it by now..
But yes, paying $50 for a turbo and $60 for a rebuild kit is alot cheaper then buying it rebuilt from somewhere..
Old Jun 25, 2004 | 11:26 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">You're a junkie... I was dubbed junkyard warrior a couple years back. </TD></TR></TABLE>
For some reason I think we had this conversation before.. Just seem too familiar..
HamiltonRex
Jan 24, 2010 09:48 AM
turbotime
Mar 30, 2006 02:07 PM
kaychi
Jan 28, 2006 12:43 AM
PHILLIPDEEZ
May 18, 2005 03:49 AM
da_konig
Apr 24, 2004 06:12 AM
