what rod bearings do use for my eagle rods in my b18b?
i am stalled in the process of putting eagle h beams in my b18b block. does anyone know which color bearings to use? i do not have my old ones to look at. thanks
Re: what rod bearings do use for my eagle rods in my b18b? (ls95hatch)
Get Standards.. dont buy Dealer bearings given I doubt you can color match them to fit.
Moderator
Re: what rod bearings do use for my eagle rods in my b18b? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">Get Standards.. dont buy Dealer bearings given I doubt you can color match them to fit.</TD></TR></TABLE>
you obviously don't know how to do it right!!!
don't get standard bearings....do it the right way and clearance them in!!!
Re: what rod bearings do use for my eagle rods in my b18b? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
ok how to clearance them? or you talking measure them and use the honda chart for fit? Last time I saw a honda chart it only gave you a reference of number and letter to get a color to purchase.
I usually use ACL standard bearings and have yet to have a problem with fit on my engine rebuilds
i bought acl bearings and they were way off. so does anyone know the sizes that go with the colors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls95hatch »</TD></TR><TR><TD CLASS="quote">i bought acl bearings and they were way off. so does anyone know the sizes that go with the colors?</TD></TR></TABLE>
What do you consider way off?
i got Clevite STD size bearings with my eagles on the D16Z6
the clearance were perfect... on the .2 side
i say, get standard, plasti gate them, and go from there into oversize or something
Moderator
Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">the clearance were perfect... on the .2 side
that is not perfect for a car that you want reliability on!! hUnda recommends .0013
Re: (chad)
that is not perfect for a car that you want reliability on!! hUnda recommends .0013</TD></TR></TABLE>
i am at work and dont have the specs with me
i had it on the plastigate 2 bar ( 0.02, 0.002, 0.2 wichever, i cant remember now, u should know what i mean)
wich means u have it on the loose side a lil bit
Honda makes the clearances to last on a motor for 200k miles
if u want peak performance u want it a lil looser than stock to get better lubrication, less friction and best response
way before this engine reaches another 100k , i will be rebuilding it again.....
so whats ur point?
so whats ur point?
Re: (chad)
What makes you think the clearances that Honda recommends for a STOCK engine will be good for an engine designed for high performance with aftermarket parts?
