Upper Radiator Hose Diameter--2000 Civic EX
Upper Radiator Hose Diameter--2000 Civic EX/B18b hybrid
Hey whats up guys, I am investing in a Greddy Water Temp Sensor Adapter..but wasn't sure which to order. They come in 30mm, 34mm, and 36mm. Do you guys have any ideas as to which one I should order? 2000 Civic EX/B18b Hybrid
Thanks,
Khoi
Modified by Sohc Driver at 12:42 AM 6/21/2004
Modified by Sohc Driver at 12:44 AM 6/21/2004
Thanks,
Khoi
Re: Upper Radiator Hose Diameter--2000 Civic EX/B18b hybrid (Honda Hick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick »</TD></TR><TR><TD CLASS="quote">Just go outside with a tape measurer and measure your rad hose.</TD></TR></TABLE>
Because I prefer not to unhook it and let the coolant run out...it would be a lot simpler if someone just has one laying around.
Khoi
Khoi
Re: (DaX)
awesome..Thanks Dax..but I guess if i ordered a 30mm OD adapter..i would just have to clamp the hose tight around the adapter..
This is for my greddy water temp sensor BTW
Khoi
Khoi
Re: (Sohc Driver)
Does it matter where you put the sender for the water temp? Im a bit hungover right now... which way does the water flow? pump to thermostat or thermostat to pump?
mingbling96
06-01-2005 08:19 PM
Sohc Driver
06-21-2004 10:20 AM
