TurboXS dual stage boost control
I need some help on figuring out how to get my scramble switch triggered when shifted into 3rd gear. I have thought about a switch mounted on the console and triggered when the shifter hits it but it gets in the way when you shift 5th.
ANy ideas??
ANy ideas??
Re: TurboXS dual stage boost control (pip9)
is the swich flipped automatically? I need some sort of automatic switch so she wont have to worry about flipping it.
Re: TurboXS dual stage boost control (Jared)
Maybe try using the speed sensor signal.....figure out what mph you are going as soon as you shift into third at WOT. Ofcourse you would have to have some sort of circuit to process the signal.......
Re: TurboXS dual stage boost control (StreetMod)
sounds pretty complicated. The car has no stock ecu so the vss is dead. I was just hoping you guys may have rigged up a switch to trigger in 3rd or whatever gear and had some pics for ideas.
Re: TurboXS dual stage boost control (30psiCiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv »</TD></TR><TR><TD CLASS="quote">sounds pretty complicated. The car has no stock ecu so the vss is dead. I was just hoping you guys may have rigged up a switch to trigger in 3rd or whatever gear and had some pics for ideas. </TD></TR></TABLE>
I hit it in 2nd ;-)
I hit it in 2nd ;-)
DEZn00ts
12
11-06-2015 06:46 PM
crex23
12-05-2005 12:28 PM
