Best Turbo Enginge Management System for PW0 ECU???
Hallo,
does anyone know a good working solution for a PW0 European ECU for Turbo application?
Hondata only support JDM PW0 ECUs and i found nothing cheap alternitive...
can anyone help? is there anyone driving around with a Euro PW0 ECU and boost?
Thanks
Malte.
Thanks
Malte.
Re: Best Turbo Enginge Management System for PW0 ECU??? (mrx)
i belive you might want to check out http://www.pgmfi.org (i think that is the site)
look into "turbo edit" and "chrome"
Re: Best Turbo Enginge Management System for PW0 ECU??? (Dturbocivic)
Nice try, but there is no boost code for PW0 available... so i'am searching for good alternitives!!!
I've got the same "problem" that you've got. I've searched a lot on the internerd. In the US the PW0 is very rare, thats why there's a lot of development on the non-VTEC Civic/CRX.
The best option is to get a PM6 (non-VTEC Civic/CRX ECU) and run TurboEdit. You can't use VTEC though, so you have to have something to activate VTEC. I'm going to use my A'PEXi V-AFC to do the job. But you can also get a PS9 ECU. It's a PM6 for automatic transmission. The extra lines for the automatic transmission is used to activate VTEC. Or you can convert the PM6 to PS9. There's a threat on http://www.pgmfi.org in the TurboEdit section about how to do that.
Re: Best Turbo Enginge Management System for PW0 ECU??? (JOeS)
Hi,
i thought about that also but the vtec solution is not the best... hmm... but as it seems there is no better way...
i will think about it.
Thanks
Malte.
Thanks
Malte.
Other option is Zdyne.
Other "free" option is OBD1 conversion and run a P28 ECU.
