Turbo Sohc
Old Jul 5, 2004 | 09:43 PM
fastciviccoupe's Avatar
Default Turbo Sohc
Hey guys im kinda new to the turbo forum and i just had a question. Im currently driving a 95 ex coupe and i was considering going turbo. My only question is about how much horses will i see if im running about 9-10 psi with a basically stock bottom. And ppl with turbo shoc what type of times are yall running? im looking 2 make around the high 12's very low 13's.
Thanks 4 all the replies in advance
Old Jul 5, 2004 | 09:51 PM
null.'s Avatar
Default Re: Turbo Sohc (fastciviccoupe)
well some common numbers people get from turbo-ing a stock sohc can range from 180-220, the main key to getting good numbers and keeping the motor in good shape is tuning. only guy i know that ran 12s on a stock sohc was the guy who had an EF with a d16z6 swap. but then again that is an EF which was gutted out
Old Jul 6, 2004 | 06:54 AM
tgreaves's Avatar
Default Re: Turbo Sohc (egb18turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18turbo &raquo;</TD></TR><TR><TD CLASS="quote">only guy i know that ran 12s on a stock sohc was the guy who had an EF with a d16z6 swap. but then again that is an EF which was gutted out</TD></TR></TABLE>
Ill be there soon.. Look below..
You can get into the 13's pretty eaisly with 8-10 psi on that car.. I just depends on how good of a driver you are and how well tuned your car is..
Old Jul 6, 2004 | 09:56 AM
thanks for the info
Old Jul 6, 2004 | 10:09 AM
tgreaves's Avatar
Default Re: (fastciviccoupe)
I guess the key to what times you run is do you care about blowing your motor.. When your pushing a stock sohc motor that hard if everything isnt right youll blow it..
streetcartuner
13
Jan 3, 2007 04:26 PM
jimbeamsEK
Jul 21, 2005 06:52 PM
SOHCsleeper
32
Jun 5, 2005 09:50 AM
blkeg
Jan 17, 2004 03:33 PM
J T*
Jan 16, 2002 06:12 PM
