looking for turbo recomendations..not honda!
Car: 98 Volvo S70 T5 manual
I upgraded to a slightly larger than stock mitsu turbo earlier this year and ended up bending 2 or 3 rods. I've had the motor built and now i'm looking for a larger turbo that can get me to ~400whp.
engine is 2.3l 5cyl 20 valve .020 over bore, 8.1:1 CR
what sort of A/R and trim should I be looking for to have it spool fairly early but not choke out up top?
Re: looking for turbo recomendations..not honda! (Chip)
id say for you because you want quick spool, a really big T3/T4 like an SC63 or SC61
Me personally I would run a straight T4 like a t4/t4R or T4/60-1 .70 a/r
Re: looking for turbo recomendations..not honda! (Stickdeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stickdeath »</TD></TR><TR><TD CLASS="quote">HONDA-tech, HONDA-tech, not Volvo-tech
you get the </TD></TR></TABLE>
No... you get the . What does it matter if it isn't a Honda? It is still a FI question.
Re: (BlackT5)
Wondering why the sleeves have a gap in the middle of them? If my B16 had that id be on the phone with the machine shop .. unless Im missing something.
Id say t3/67 .. thats the biggest t3 they make right?
Re: (BlackT5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackT5 »</TD></TR><TR><TD CLASS="quote">6500-7000rpm</TD></TR></TABLE>
Then the .63 A/R Turbine Precision Trubo SC61 will do you good.
Maybe even a .63 Turbine SC34 might work. A little smaller compressor, but still capable of 400 HP.
Re: (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP »</TD></TR><TR><TD CLASS="quote">Wondering why the sleeves have a gap in the middle of them? If my B16 had that id be on the phone with the machine shop .. unless Im missing something.
If you look closely, you can see the crack only goes about 1/2 cm down from the deck. It's prolly a little area for the coolant to go to keep things cool between the cylinders.
Looks like a good idea actually.
Re: looking for turbo recomendations..not honda! (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">t3/67 from fr</TD></TR></TABLE>
He said 400 WHP, not 600 WHP. Heck, why stop there. I think you should run a T76-GTS! 1000 WHP capable, but who cares!
For real dude. Its still a FI question. There is lots of us here that have other cars other then hondas. THey just like the forum here. If you dont have anything good to say, dont say anything.
As for the questions at hand, a 50trim t3/t4 will put out about 450whp at peak, a 60trim t3/t4 will get ya almost 500 at peak.
Actually a pretty badass turbo might be a straight garrett GT30R - it has a .84ar housing which should work very well with the 2.3 litre, and still support a little over 500whp. Not to mention it will spool up VERY fast on your car.
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip »</TD></TR><TR><TD CLASS="quote">
He said 400 WHP, not 600 WHP. Heck, why stop there. I think you should run a T76-GTS! 1000 WHP capable, but who cares!</TD></TR></TABLE>
So basically you recommend the sc61 but spite the idea of getting a t3/67.
Re: looking for turbo recomendations..not honda! (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr »</TD></TR><TR><TD CLASS="quote">
So basically you recommend the sc61 but spite the idea of getting a t3/67. </TD></TR></TABLE>
Yea both those turbos are too big. GT30R is where its at.
liam
liam
So basically you recommend the sc61 but spite the idea of getting a t3/67. </TD></TR></TABLE>My thoughts.
At what RPM do you want full boost. How much boost are you running? Are you against buying a turbo that is overkill, good for 500+whp?
Justin
Justin
full boost by 3500rpm. I'm not sure how much boost i'll be running. I'm not going to upgrade for a little while but thought I would start researching.
Modified by BlackT5 at 9:42 AM 7/4/2004
