D Series build help
Old Jul 4, 2004 | 07:02 PM
onePOINTsix's Avatar
Default D Series build help
Well i'm finally about to get started on my D16 build for my CRX HF, the planed list of parts is as follows:
9.1:1 SRP Pistons
Eagle H-Beams
D16Y7 block
D16Z6 head and intake manifold
D16A6 crank (micropolished)
460cc N/A RX7 injectors
Y8 head gasket
ss autoslum manifold (will be hella renforced)
Tial 38mm wastegate
T3 Super 60
ARP Headstuds
HF stock oil cooler
Intercooler is still unknown, whatever i can get for a good price
Now for my questions:
1. I plan on hitting a max of 15psi (only for tuning and drag days), is that safe on the stock sleeves with no block guard?
2. Is 15psi on 9.1:1 pistons good for around 225hp?
3. Should i upgrade my fuel pump?
I'm probally going to Godspeed and tune it with turboedit on their WB02/Dynapack
edit: added a few things to the build list
Modified by Sideout at 11:53 PM 7/4/2004
Old Jul 4, 2004 | 07:23 PM
JDMCRX's Avatar
Default Re: D Series build help (Sideout)
U should be able to hit 225 no prob at that boost.
Fuel pump i would upgrade. I did mine for security.
Old Jul 4, 2004 | 07:50 PM
Default Re: D Series build help (JDMCRX)
ok, but now for the question, am i going to break a sleeve? I'm going to run uber low boost untill i get it properly tuned
edit: for the picture people
Modified by Sideout at 12:35 AM 7/5/2004
Old Jul 4, 2004 | 09:00 PM
B18C1CYA's Avatar
i personaly wouldnt boost at all until its tuned, your just asking for trouble
Old Jul 5, 2004 | 03:09 AM
oscarmayer's Avatar
the stock sleeves can handle up to about 16-17psi before you take a chance of breaking them. if doen right at 15lbs you should hit about 300-310wheel power. You'll be fine. I took a totally stock motor for 9 months and ran 14lbs and hit 246wheel power. i mean stock nothing doen to it except turbo stuff. I was using a hondata with 440 injectors at the time.
Old Jul 5, 2004 | 10:38 AM
RyanEJ8's Avatar
Default Re: D Series build help (oscarmayer)
Stock sleeves should be able to hold way more than 16-17psi on that turbo.
Jeremy Pooler
Jan 3, 2017 12:44 PM
Ding
Apr 18, 2006 04:38 AM
USDM 4G VTEC
27
May 24, 2004 03:35 PM
gigantor
May 9, 2002 04:42 PM
