strongest tranny ??
Old Jul 7, 2004 | 12:58 AM
civickiller's Avatar
Default strongest tranny ??
ok i have the opportunity to pick up either a gsr hydro or a b16 cable. i have heard that cable trannies are better because the casing is stronger then the hydro casings, does anyone know if this is true ? what are you high hp (400whp+) guys using for trannys and how are they holding up ?
im not really worried about replacing syncros or diffs, im just wondering which one is a stronger tranny to get. i did try search but i couldnt come up with anything
thanks
Old Jul 7, 2004 | 03:25 AM
greekspeed's Avatar
Default Re: strongest tranny ?? (civickiller)
well i never heard of the casing difference , but everything internally between any b-series tranny is made with the same grade of materials...so they all hold up about the same amount of power. the only difference between them is gearing ratios, and lsd vs no lsd.
Old Jul 7, 2004 | 08:13 AM
Default Re: strongest tranny ?? (greekspeed)
does anyone know how much hp hte stock gears will handle in stock honda trans ?
nobody know anything about strength of hte casing between cable and hydro ?
Old Jul 7, 2004 | 09:40 AM
m R g S r's Avatar
The gears themselves can hold alot of power, it just depends on how much you beat on the car and hurt the syncros and such. .
Old Jul 7, 2004 | 10:08 AM
99B16Si's Avatar
GSR has a stronger factory diff than a B16/LS tranny
Old Jul 7, 2004 | 10:26 AM
AL ASPIRATED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">ok i have the opportunity to pick up either a gsr hydro or a b16 cable. i have heard that cable trannies are better because the casing is stronger then the hydro casings, does anyone know if this is true ? what are you high hp (400whp+) guys using for trannys and how are they holding up ?
thanks</TD></TR></TABLE>
wat car is it going into? what motor? wat are you plannings? boosting, NA?
Old Jul 7, 2004 | 10:30 PM
Default Re: strongest tranny ?? (AL ASPIRATED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AL ASPIRATED &raquo;</TD></TR><TR><TD CLASS="quote">
wat car is it going into? what motor? wat are you plannings? boosting, NA?</TD></TR></TABLE>
91 hatch, b18b. i plan on boosting, around 25psi and 500whp. gonna be a street car but run at the track alot.
what kind of trannys do you 400+whp guys use for trannys ?
i hear me that cable tranny casing are stronger then hydro casing.
what do you recommend getting ?
Old Jul 8, 2004 | 11:39 AM
bump
Old Jul 9, 2004 | 12:16 AM
bump
i need some advice on which one i should pick up
and more info on which one will hold up to the power i plan on making, diff dont matter cause i plan on putting a lsd in it anyways
help me out
JDM_rolex
May 17, 2007 01:44 PM
mymeatb18"
Apr 20, 2007 09:18 PM
drSquish
Dec 12, 2005 03:17 PM
HT Chaplain
Mar 16, 2005 07:59 AM
jdmlife
10
Apr 12, 2004 11:32 PM
