leaning out as soon as full boost comes in
Re: leaning out as soon as full boost comes in (1 POINT 8)
what size injectors do you have? slap on a fmu and throw in a walbro. if it's stock go with a 12:1 disc on the fmu. don't drive the car until you do this. purchase an afc and go to your dyno and go and tune it.....or save up and buy a hondata. oh no, turbocharging and doesn't have a clue about it.....all i can say is due a compression check you could've already ruined your motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 POINT 8 »</TD></TR><TR><TD CLASS="quote">as the title says please help </TD></TR></TABLE>
Sure, head back down to the shop that tuned your uberdata/hondata/aem/haltec/motec/vafc-hack/fmu set-up and ask them to take a look at your air/fuel ratio. Tell them your automter air/fuel ratio gauge is only lighting up in the red.
It's kind of hard to help you with NO information provided.
I'll help you if you tell me how to fix my oil leak, it's coming from the front of the car, please tell me whats leaking and how to fix it.
Re: leaning out as soon as full boost comes in (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
lol +1
oh and my car wont hit vtec...any ideas
lol +1
alright i have a vortec fmu, walbro 255 intake fuel pump, and stock injectors. its only on 7 psi, what else would u need to know i dont know what the disk in the fmu is its what came with a drag kit.
my boi had an fmu and his vafc and was leaning out at 6psi. we just threw some 440cc injectors in took the fmu out and set the fuel pressure reg. at 50 at idle. now he's running rich at 6psi, but thats what we want until he gets his hondata hooked up, so atleast you would know you not going to detnate with too much fuel. so that's my suggestion until your car is tuned.
Re: (1 POINT 8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 POINT 8 »</TD></TR><TR><TD CLASS="quote">alright i have a vortec fmu, walbro 255 intake fuel pump, and stock injectors. its only on 7 psi, what else would u need to know i dont know what the disk in the fmu is its what came with a drag kit.</TD></TR></TABLE>
it shouldnt lean out at 7psi. FMU's ten to over fuel a bit at that low of a boost level. u sure u have the lines right on the fmu?
Re: (1 POINT 8)
A wastegate won't cause a rich or lean condition, it regulates boost pressure. Unless the wg is crap it should hold boost at whatever psi it's set for. The only time a lean condition can be contributed to a wastegate is if it's spiking, but thats not the wastegate thats making you run lean its the extra boost pressure without the extra fuel. But you said your only boosting 7psi so it's not your wastegate
Re: (b16ahybrid)
i think your problem is that you are using an INTANK fuel pump when you should be using an inline fuel pump.. inline fuel pumps are capable of supporting high fuel pressures needed, especially for those using FMU's.
i was going to buy hondata but im selling the motor and turbo setup, so thats the only reason i dont buy hondata if you know anyone looking for 98 LS motor and turbo kit send them my way.
Re: (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT »</TD></TR><TR><TD CLASS="quote">i think your problem is that you are using an INTANK fuel pump when you should be using an inline fuel pump.. inline fuel pumps are capable of supporting high fuel pressures needed, especially for those using FMU's.</TD></TR></TABLE>
Intank pump are fully capable of supporting 7psi of boost with stock injectors, UNLESS the intank is stock.
