GE oil sandwhich plate
i wanna get a golden eagle oil sandwhich plate for my ls vtec turbo that has a -4an for the vtec oil line and the turbo oil line... anyone know if golden eagle sells -4an oil sandwhich plate for both the turbo and the vtec head oil lines? i see on their website that they have -8an -10 and etc
Re: GE oil sandwhich plate (tRaCeBuStAbUsTeR)
just get the vtec conversion one from ge has a 1/8'' port and one to feed the head which i think is -6, and the oil is filtered oil, iam running one and its great
Modified by B18C1CYA at 7:54 PM 7/8/2004
Re: GE oil sandwhich plate (B18C1CYA)
With our kit you can use anything you need. The sandwich plate has a 1/8 npt that we sell -3 and -4 AN fittings for, and the other port is a 3/4" boss that we have an adapter to make it either a 1/8 or 1/4 NPT. Then you can just get another -3 or -4 AN ( depending on what size your turbo oil feed line is ) and voila! Ready to go! So let me see, you need the following:
Golden Eagle Sandwich plate - GVC101
1/8 NPT to -4 AN fitting - GAN-4-1/8NPT
3/4" to 1/8 NPT adapter - G3/4BOS 1/8NPT
Tell me what size your turbo oil feed line is and I can get you the last part # you will need to get everything together!
Re: GE oil sandwhich plate (GoldenEagleMfg.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com »</TD></TR><TR><TD CLASS="quote">With our kit you can use anything you need. The sandwich plate has a 1/8 npt that we sell -3 and -4 AN fittings for, and the other port is a 3/4" boss that we have an adapter to make it either a 1/8 or 1/4 NPT. Then you can just get another -3 or -4 AN ( depending on what size your turbo oil feed line is ) and voila! Ready to go! So let me see, you need the following:
Tell me what size your turbo oil feed line is and I can get you the last part # you will need to get everything together! </TD></TR></TABLE>
Great products and great support. GE gets a from me.
Qty Description Part #
1 - Golden Eagle Sandwich plate - GVC101
2 - 1/8 NPT to -4 AN fitting - GAN-4-1/8NPT
1 - 3/4" to 1/8 NPT adapter - G3/4BOS 1/8NPT
This is what you will need.
sorry to thread jack. what does the sandwich plate does? my bro said i need one for my car and i dont know which one to get.
Hello,
Can you use a after market oil cooler sanwhich adapter on top the GE one. I want a nice place to run my turbo oil feed and oil sensor, but I might want to also go with a oil cooler. So will this work?
Thanks
Thanks
Re: GE oil sandwhich plate (eddyboy)
Yes, anything you can screw onto the oil filters normal location onto the block, then it will fit our piuece. Think of it as an extension of your block!
