need help burning chip with Flash & Burn
Old Jul 4, 2004 | 07:10 AM
civperc's Avatar
Default need help burning chip with Flash & Burn
Well, I'm stuck in my turbo install process because I'm having trouble with using Flash & Burn in conjunction with my Moates.net chip burner. I've set the COM ports and everything like that, however I can't find any info on any websites about what to type into the hex/address/etc fields or which options to use in whatever order.
I'm trying to burn my basemap .bin file to a 29c256 chip and really need to know how to use Flash & Burn to properly get this done. Thanks in advance, need to get this done ASAP.
Old Jul 4, 2004 | 01:56 PM
Brad's Avatar
Default Re: need help burning chip with Flash & Burn (NewOldSkoolr)
I didn't touch any addressing settings in the flash n burn exe. To burn a chip just click the Load File to Buffer button, select your bin, then click program chip.
Old Jul 5, 2004 | 09:10 AM
scttydb411's Avatar
make sure you click on the appropriate chip...erase the chip...then load file to buffer. then program chip. the addressing should already be set in flash n burn.
Old Jul 5, 2004 | 11:28 AM
blackeg's Avatar
Default Re: (scttydb411)
^^^. and also, it wont hurt to do blank checks before and after you burn the chip. ive heard that you need to close out the tunerpro program before you remove the chip, but i dont personally remember how i did it.
raverx3m
Northwest
Apr 11, 2012 12:47 PM
jedsus
Engine Management and Tuning
Apr 25, 2008 08:36 PM
the.hamburglar
Mar 20, 2006 03:28 PM
alexsracing
Nov 27, 2004 11:37 AM
Turboholic
Aug 18, 2004 09:52 AM
