sohc turbo...safe to run stock dsm boost pressures stock internals?
on any relatively good condition d-series engine (92+ DX/EX/etc.).. how safe is it to run the stock boost pressures of the 14B and T25 turbos from eclipses? i mean ive seen many examples from people at homemadeturbo.com and such -- im just worrying and over-thinking about it (its my bad habit)
im assuming with proper engine management its do-able? or is it a 'better' idea to mess with the actuator to turn down the boost to a safer 6-8psi?
thanks for any help
maybe i should just take my friends advice "don't worry.. you can replace your motor for like 200 or less"
thanks for any help
Re: sohc turbo...safe to run stock dsm boost pressures stock internals? (Sean EH2)
thanks for the replies.. i probably could've searched but its 3 in the morning and i dont think too quickly.
just off the top of my head.. the 14B is stock-set to 12psi? or is it iess.
Just remember the 14b flows a tad bit more than the t-25. I'd have to say 10-11 psi on a t25 safely, and maybe 7-8 on a 14b.
Re: sohc turbo...safe to run stock dsm boost pressures stock internals? (nabyar)
14b stock is set at 8-9psi,on dsm its 12-13psi cause of the computer. first motor i turbo was a 1.5 with the 14b , on a highway run it overboosted to 14psi and it blew in about seconds rods are super weak they all flew out the block. so 12psi on a dx is def a bad idea unless its built, a zc motor will most likely handle it due to the bigger LS style rods.but tunning will also play a big role
Re: sohc turbo...safe to run stock dsm boost pressures stock internals? (hotintegranights)
It's not the boost level, but the power level. Once you start going 200whp and up, is when it gets iffy with the D series rods. This is, of course, with the right management. And remember, the stock MAP sensor can only read up to 10 or so psi.
