ls/vtec timing covers
Old Jul 6, 2004 | 12:44 PM
tthame1's Avatar
Default ls/vtec timing covers
what timing will i need with a 94 ls block and a 1st gen b16 head and type r oil pump. i have already found out the b16 covers wont work. any help would be awesome. thanks.
Old Jul 6, 2004 | 01:03 PM
Turbocivic94's Avatar
Default Re: ls/vtec timing covers (tthame1)
U have to use obd2 timing covers from any B series
Old Jul 6, 2004 | 01:22 PM
tthame1's Avatar
well i have the lower timing cover for a type r and it works fine but i have the upper rear timing cover for a gsr and it doesnt line up at all. the left side has about a inch gap in it when the cover is bolted down and the b16 is to short so any other suggestion.
Old Jul 6, 2004 | 04:45 PM
BROOD's Avatar
I have used OBD1 LS upper/inner platics with no problems. Some slight trimming of material was needed but it worked fine.
My current ones:
OBD1 LS block, OBD2 ITR oil pump, B16A cyl head.
OBD1 LS upper/inner plastic, any Bseries upper/outer plastic, and a lower plastic for the oil pumps with a CKP sensor.
boosted k20
Oct 16, 2017 11:11 PM
n0y
Feb 18, 2010 01:19 AM
joedr
Jun 26, 2008 01:03 PM
b16vtecsol
Jan 23, 2004 07:29 AM
