max boost for a block guard
Old Jul 6, 2004 | 10:09 PM
CANTFAZZDISCHIT's Avatar
Default max boost for a block guard
will putting a block guard in my b16 block allow me to run more boost, i have rods, pistons.... yadah..yadha..yadha, and want to run 18psi, will the cylinder walls take this with the block guard??
Old Jul 6, 2004 | 11:22 PM
pngfolife's Avatar
Default Re: max boost for a block guard (CANTFAZZDISCHIT)
Your stock sleeves can easily hold this amount of boost. The block gaurd prevent the sleeves from "walking" or shifting under the increased pressure of combustion. When cylinders walk, head gaskets blow. It sucks having to change your head gasket every time you turn up the boost. If you plan on running more boost though, you whould think about just having the block sleeved. Ductile iron sleeves = OEM reliability under high boost applications.
Old Jul 7, 2004 | 03:49 PM
Circuit Star-29's Avatar
Default Re: max boost for a block guard (pngfolife)
Well stated.
Old Jul 8, 2004 | 07:29 AM
AccordDX89's Avatar
What about 10 psi? Will block guard work well for that or are sleeves still recommended?
Old Jul 9, 2004 | 07:18 PM
pngfolife's Avatar
Default Re: max boost for a block guard (AccordDX89)
You should be fine up to 1 bar.
tobe1424
Aug 16, 2005 10:11 AM
PIFFSTAR
Feb 15, 2005 06:49 AM
aut0tek
Apr 2, 2003 02:50 AM
The_Robster
Oct 30, 2002 02:41 PM
B18CHatch
Oct 18, 2001 03:06 PM
