Can u run a hondata chipped ecu with out the s200b box
i just recently sold my hondata s200b. i know uberdata u dont need nothing to run the burned chip and was wondering if i could do that with a hondata chipped ecu? also how hard would it be for somebody to make me a basemap from uberdata using my hondata chip as i plan on going uberdata this time around. thanks i know this is a tech question but most people running standalones r turbocharged.
Re: Can u run a hondata chipped ecu with out the s200b box (Prelude91siT)
to get your maps into uberdata you can just type all of the values into the uberdata maps. I've tried opening up hondata fuel and ignition maps with uberdata before and it wouldn't work.
Re: (Prelude91siT)
Hondata/Uberdata are nothing more than software that allow you do change fuel, ignition, vtec, etc... They both require you to use a chipped Honda ECU. So to answer your question yes your chipped ECU will work with uberdata. The blue box that comes with hondata doesn't run anything, it's just a security device so people can't hack into the hondata coding. It shouldn't be too hard for a tuner to create a basemap for your car in uberdata.
Re: (Prelude91siT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT »</TD></TR><TR><TD CLASS="quote">ok thanks for the replies. so can i run my hondata chipped ecu with out the box? </TD></TR></TABLE>
Are you asking if you can run your ECU with the Hondata bin file on the chip without the s200 blue box? If so I dont think that you can. Im about 99% sure that you need the box conected. Some one please correct me if Im wrong.
does anybody know y this is. as u dont need to run no box for any other chipped ecu. i thought mabye its gives u the option to datalog and stuff. like if u hooked up ur uberdata ecu to datalog. any more suggestion or anwers would be appriecated.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT »</TD></TR><TR><TD CLASS="quote">i just recently sold my hondata s200b. </TD></TR></TABLE>
who did you sell it to?
Re: (Prelude91siT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT »</TD></TR><TR><TD CLASS="quote">does anybody know y this is. as u dont need to run no box for any other chipped ecu. i thought mabye its gives u the option to datalog and stuff. like if u hooked up ur uberdata ecu to datalog. any more suggestion or anwers would be appriecated. </TD></TR></TABLE>
if you didnt need the s200 box then anyone could run the hondata without paying for it. its there for security measures.
Hoodwinked
01-05-2005 01:11 PM
