safc blue wire mod
Old Jul 3, 2004 | 04:12 PM
InLimbo87's Avatar
Default safc blue wire mod
I hooked up my safc today and hooked the blue wire up to the red wire with the white stripe. is this the right wire for obd1. someone said it was the white/red wire but im not sure if that meant white wire with red stripe. thanks guys.
Old Jul 3, 2004 | 05:05 PM
MooreBoost's Avatar
Default Re: safc blue wire mod (tegsedan)
Whats the point of this?
Old Jul 3, 2004 | 08:33 PM
InLimbo87's Avatar
Default Re: safc blue wire mod (tegunderpressure)
the safc can read the o2 voltage from the stock narrowband sensor if you hook up the o2 wire going into the ecu to the extra unused blue wire on the safc harness. Im just going to be using it to kind of ghetto tune it till i can afford a wideband, or hondata. If you search under blue wire mod theres some info on what voltage levels are considered lean, rich, or stoich. check it out. btw, anyone can you help me find that o2 voltage wire??
Old Jul 3, 2004 | 08:48 PM
MooreBoost's Avatar
Hmm, pretty cool idea. Good luck with it.
Old Jul 3, 2004 | 09:12 PM
InLimbo87's Avatar
found my answer. for anyone looking for it it is supposedly a white wire on slot d14 of the obd1 ls ecu.
aznryd3r
Nov 24, 2006 10:05 AM
dsm this
Mar 15, 2004 02:42 AM
LostCRX
Mar 8, 2004 12:58 PM
arjusmc
Jul 2, 2003 03:57 AM
vtecsiqt
Apr 22, 2002 12:48 AM
