1.8l d16z6 motor build up
Currently i have a sleeve jg block which will be 79mm
i am going with cp 9:1 comp pistons and eagle rods.
Ported head wit a skunk manifold skunk springs and retainers
and hondata.
which turbo would u guys recommend and do u guys think its safe to go 79mm bore on a sohc? has it been done??
what kinda power do u guys think i can make?
thanks for ur time
and hondata.
thanks for ur time
Re: 1.8l d16z6 motor build up (nutzurchin)
Sounds like a beast of a set-up. What do you plan on revving the engine to? If your going to go to 8k+ i say go with a big snail like a sc61 or a gt35r. As far as the 79mm bore, how much sleeve is there between cylinders? As long as there is enough room for the headgasket to get a good strong seal than i say go for it.
With a build up like that id shoot for around 350-400whp without stressing that headgasket.
Re: 1.8l d16z6 motor build up (Devine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devine »</TD></TR><TR><TD CLASS="quote">Sounds like a beast of a set-up. What do you plan on revving the engine to? If your going to go to 8k+ i say go with a big snail like a sc61 or a gt35r. As far as the 79mm bore, how much sleeve is there between cylinders? As long as there is enough room for the headgasket to get a good strong seal than i say go for it.
With a build up like that id shoot for around 350-400whp without stressing that headgasket.</TD></TR></TABLE>
well cometic makes a 79mm head gasket. so some one has gone this big on a sohc.
http://www.sohchonda.com
http://www.turbod16.com
Check those forums out. There are a few guys doing big 450+whp builds.
I think Ladysman "big block" d is 78mm bore.........biggest I have heard of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutzurchin »</TD></TR><TR><TD CLASS="quote">only 350-400whp?? i was hoping 400-450.</TD></TR></TABLE>
You'll notice i said without stressing the headgasket, it really depends on how thin that headgasket is between the cylinders, a good friend of mine had a 85.5 mm boosted ls/vtec, i know his headgasket was only a few mm wide between cylinders..... he still made over 400whp but you never know when the cylinder pressure could blow that headgasket. Im sure your set-up is more than capable of handling over 500 whp but you could be chancing it. I definately wouldnt push it if this is your daily driver.
Sorry I don't have any advice for you, but a question.... do you think that a b-series motor with a comparble setup would put out about the same power and torque? If so, then dam you have a nice *** motor (regardless) on your hands...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutzurchin »</TD></TR><TR><TD CLASS="quote">Currently i have a sleeve jg block which will be 79mm
and hondata.
thanks for ur time</TD></TR></TABLE>
and hondata.
Re: 1.8l d16z6 motor build up (StreetMod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetMod »</TD></TR><TR><TD CLASS="quote">http://www.sohchonda.com
Yes, I have a 78mm block that was built by Endyn. Larry (at Endyn) won't build anything bigger than 78mm for boost. My headgasket wasn't that bad but a 79mm I think would be too far. Let us know though if you decide to do it. I would like to know the results.
OG triple OG
79mm , i wouldnt boost on that .
cp pistons are the absolute **** i have those . eagle rods are a nice choice , make sure you get the good rod bolts .
and im going to run a gt35e on my sohc setup . others are runnning the sc61
Re: 1.8l d16z6 motor build up (Hella_JDM)
why would u not boost 79mm???? isnt it like sayn dont boost a 84mm gsr??
pretty much doin the same thing to a d series as u would do a b series. goin 4mm over, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">no , because an 84mm gsr still has enough meet on the sleeves . i wouldnt go over 3mm above stock bore.</TD></TR></TABLE>Sounds like he's got it. Just going to have to make sure the tuning is spot on. Not much hope for a rebore. SC 52 or 60 should give you what your after. http://www.wiredspeed.com/item...c=PRE
Re: 1.8l d16z6 motor build up (turbozxi)
I would be very careful pushing JG sleeves to 79mm.
They dont have the greatest reputation, and they frankly look like they're just re-lined blocks with a welded in block guard...
Elitesky
12
08-05-2010 10:48 AM
