Boost w/ Factory Cast Pistons
Hey guys,
I'm wondering, in your experience, how far have you pushed the factory cast pistons without failure in terms of HP on the B16A? Lots of people talk about max boost on the stock block, but thats somewhat irrelevant.
Here's my current setup, producing 236whp, 187tq @ 9psi:
B16A, stock block, pistons, rods, crank, ignition.
Intake Cam -2, Exhaust Cam +2 (to reduce overlap)
Precision SC44 Turbo, .48 A/R
Turbosmart 45mm Ultragate
Precision 440cc injectors @ 44psi
Walbro 255lph in-tank fuel pump
2.75" downpipe, hollow cat, greddy exhaust
P30 ecu, professional techtom programming, conservative timing, 11.5:1 a/f
Turbosmart e-boost controller
From what I've heard so far, reliable sources claim I'm already pushing the factory cast pistons too far at 9psi. I'd like to hear experienced tuners thoughts on this please, not posts saying I should be making more power as is. There are many others out there with a similar setup making outrageous claims of 300+ whp. I would like to skip those replies please. THANKS!
Re: Boost w/ Factory Cast Pistons (m R g S r)
I'd like to know that too, as I am really only looking for replies from people with the cast B16A pistons please.
Thanks.
Thanks.
Guest
Posts: n/a
Re: Boost w/ Factory Cast Pistons (jrponline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrponline »</TD></TR><TR><TD CLASS="quote">I'd like to know that too, as I am really only looking for replies from people with the cast B16A pistons please.
Thanks.</TD></TR></TABLE>
i know how to read, i answered your question
thanks
thanks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Well they can take a lot of power, it's just a matter of time before the ringlands go...</TD></TR></TABLE>]
conservative timing is key. it will hold longer than most think....300 really isn't pushing it. Plenty have made 400+
the 'psi' number doesn't really mean much to the motor.
the amount of power the motor is making is what determines the motor life. more power = more heat.
230whp is fine.
forged piston just give you more room for error in tuning and will handle detonation better than cast. But detontion can still kill forged material.
Above 275whp in a b16, then I'd look into forged materials.
230whp is fine.
00-501itrspec
03-18-2008 06:02 PM
2.2 teg
12-20-2006 04:09 PM
