leaking charge pipes
Old Aug 29, 2004 | 08:56 AM
toolowsol's Avatar
Default leaking charge pipes
Ok, my charge pipe has some very small leaks, but still it is annoying, I had my 16 year old cousin weld the charge pipes because he wanted to help with my turbo install, and for the most part he did a great job, but I have 1 maybe two PINHOLE leaks, so I was wondering if jbweld would work, I just want to put a layer around each weld to smooth it out a little and seal it, I'm just not sure how it would hold up to boost pressure.
Sorry for sounding wayyyy ghetto, but I don't really want to hurt his feelings by making him redo it lol...
Old Aug 29, 2004 | 09:36 AM
Sketch_hs's Avatar
Default Re: leaking charge pipes (toolowsol)
JB WELD
Old Aug 30, 2004 | 10:31 AM
toolowsol's Avatar
Default Re: leaking charge pipes (Sketch_hs)
Anyone else have any input? I think I'm going to give it a try next weekend unless anyone sees a reason it would not be a good temp. solution.
Old Aug 30, 2004 | 11:49 AM
Johnyquest's Avatar
yeah JB weld will work, but why not just grind down the welds and re-do it yourself (and don't tell him)...?
Then it will be done right and you'll both be happy.
Matt
Old Aug 30, 2004 | 12:43 PM
toolowsol's Avatar
Default Re: leaking charge pipes (Johnyquest)
I don't have welding tools, nor the experience to do it any better than he did.
Old Aug 30, 2004 | 12:47 PM
igo4bmx's Avatar
JBweld will work.
i had an old toyota intercooler for my setup when i first had it and it had a hole in the cooler..
i jbwelded it and it held up well
Failsafe88
Welding / Fabrication
Aug 5, 2011 07:42 PM
CBURKE
42
Dec 31, 2007 12:49 PM
stocker2shocker91
Sep 30, 2007 01:12 PM
bostoncal
Nov 23, 2005 02:44 PM
kaj
Nov 11, 2003 07:32 AM
